I trying to classify remote sensing imagery, and
I thought to try the i.smap module, but
when I run the i.gensigset, I always
get the same problem:
Removed a singular subsignature number 1 (9 remain)
Removed a singular subsignature number 1 (8 remain)
Removed a singular subsignature number 1 (7 remain)
Removed a singular subsignature number 1 (6 remain)
Removed a singular subsignature number 1 (5 remain)
Removed a singular subsignature number 1 (4 remain)
Removed a singular subsignature number 1 (3 remain)
Removed a singular subsignature number 1 (2 remain)
Removed a singular subsignature number 1 (1 remain)
Unreliable clustering. Try a smaller initial number of clusters
Removed a singular subsignature number 1 (-1 remain)
Number of subclasses is 0
Clustering class 12 (184 pixels)…
i.gensigset complete.
And afterwards the signature file doesn’t have any
spectral information. I really don’t understand whats happening
and the cause to this outcome.
Can anyone solve this “enigma”?
Ps: I don’t know if this information is important: I collected
about 450 samples distributed by 10 classes. I may also
add that the average number of pixels per sample is around 50.
And thanks list, for the previous tips: they were very useful.
Please, could you copy-paste the exact command you used?
Does the "maxsig=" (e.g. maxsig=20) make any difference?
Nikos
I always
Clustering class 12 (184 pixels)...
And afterwards the signature file doesn't have any
spectral information. I really don't understand whats happening
Can anyone solve this "enigma"?
Ps: I don't know if this information is important: I collected
Does the “maxsig=” (e.g. maxsig=20) make any difference?
Nikos
I always
(sorry for re-sorting the message, just to keep it easy to follow-up)
joel dinis:
Nikos Alexandris:
joel dinis:
In fact, I put maxsig=30.
i.gensigset trainingmap=amostras group=grupo subgroup=subgrupo
signaturefile=assinaturas maxsig=30
What about smaller maxsig's, like:
- maxsig=25
- maxsig=20
- maxsig=15
Nikos
> I always
clusters
clusters
clusters
clusters
happening
collected
50.
useful.
NikosA:
- maxsig=25
- maxsig=20
- maxsig=15
and even smaller than 10 perhaps since the algorithm indicates "9
remain" after the first removal.
Are the "sub-signature removals of the same amount for all classes"?
Nikos
> > I always
> clusters
> clusters
> clusters
> clusters
> happening
> collected
> 50.
> useful.
joel dinis:
Nikos Alexandris:
joel dinis:
- maxsig=25
- maxsig=20
- maxsig=15
Nikos
Also it might help to know what is contained in the trainingmap. i.e:
r.info -r amostras
> I always
clusters
clusters
clusters
clusters
happening
collected
50.
useful.
I tried, as you sugested, and the problem
remains.
Clustering class 9 (4994 pixels)…
Removed a singular subsignature number 1 (24 remain)
Removed a singular subsignature number 1 (23 remain)
Removed a singular subsignature number 1 (22 remain)
Removed a singular subsignature number 1 (21 remain)
Removed a singular subsignature number 1 (20 remain)
Removed a singular subsignature number 1 (19 remain)
Removed a singular subsignature number 1 (18 remain)
Removed a singular subsignature number 1 (17 remain)
Removed a singular subsignature number 1 (16 remain)
Removed a singular subsignature number 1 (15 remain)
Removed a singular subsignature number 1 (14 remain)
Removed a singular subsignature number 1 (13 remain)
Removed a singular subsignature number 1 (12 remain)
Removed a singular subsignature number 1 (11 remain)
Removed a singular subsignature number 1 (10 remain)
Clustering class 10 (2147 pixels)…
Clustering class 11 (266 pixels)…
Too many subclasses for class index 12
Number of subclasses set to 21
Yes, this happen to all the classes…
Maybe is something prior to the i.gensigset run.
I’ll investigate.
joel dinis:
Nikos Alexandris:
joel dinis:
What about smaller maxsig’s, like:
maxsig=25
maxsig=20
maxsig=15
Nikos
I always
clusters
clusters
clusters
clusters
happening
collected
useful.
I put r.info -r amostras
as sugested, get the following:
min=112
max=512
(This values are index to my classes.)
JD
On Tue, Apr 6, 2010 at 4:39 PM, Micha Silver <micha@arava.co.il> wrote:
joel dinis:
Nikos Alexandris:
joel dinis:
maxsig=25
maxsig=20
maxsig=15
Nikos
Also it might help to know what is contained in the trainingmap. i.e: r.info -r amostras
I always
clusters
clusters
clusters
clusters
happening
collected
useful.
As a side note:
while reading the manual of i.gensigset, I think it would be better to
"rephrase" either the above output message or the the manual directly to
make it clear that the "initial number of clusters" refers to... (what
is it?) "maximum number of (initial) subclasses" ?
I put r.info <http://r.info/> -r amostras
min=112
max=512
So, if I understand correctly, you are trying to classify into 400 separate classes?!
I'm a beginner with image classification, and others with more experience will know better, but I'll bet that's your problem. There must be many separate training areas (with different cat values) with a very similar spectral signature, and the algorithm is not able to differentiate between them.
JD
On Tue, Apr 6, 2010 at 4:39 PM, Micha Silver <micha@arava.co.il <mailto:micha@arava.co.il>> wrote:
follow-up)
joel dinis:
Nikos Alexandris:
used?
difference?
joel dinis:
- maxsig=25
- maxsig=20
- maxsig=15
Nikos
r.info <http://r.info> -r amostras
> I always
number of
clusters
number of
clusters
number of
clusters
number of
clusters
happening
collected
may also
is around
50.
very
useful.
On Tue, 2010-04-06 at 20:44 +0300, Micha Silver wrote:
joel dinis wrote:
> Hello Micha,
> min=112
> max=512
separate classes?!
I 've also thought about that Micha (I was about to suggest Joel to use
less training classes), but I was hesitant to say it :-p
Nikos
> JD
> follow-up)
> joel dinis:
> Nikos Alexandris:
> used?
> difference?
> joel dinis:
> - maxsig=25
> - maxsig=20
> - maxsig=15
> Nikos
> > I always
> number of
> clusters
> number of
> clusters
> number of
> clusters
> number of
> clusters
> happening
> collected
> may also
> is around
> 50.
> very
> useful.
> grass-user mailing list
> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
> Micha Silver
> Arava Development Co. +972-52-3665918
> http://www.surfaces.co.il
I’m a beginner with image classification, and others with more experience will know better, but I’ll bet that’s your problem. There must be many separate training areas (with different cat values) with a very similar spectral signature, and the algorithm is not able to differentiate between them.
I always
number of
clusters
number of
clusters
number of
clusters
number of
clusters
happening
collected
may also
is around
very
useful.
