[GRASS-user] A question about raster map resolutions
   The LiDAR source location has x- and y-resolution of 3 feet
(international) and several thousand cells east-west and north-south.
g.region -p for this location displays:
projection: 99 (unnamed)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: grs80
north: 1286590.24500872
south: 1240510.24500872
west: 634966.76150938
east: 664972.76150938
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
   When in the project location g.region -p produces:
projection: 99 (NAD_1983_HARN_StatePlane_Oregon_North_FIPS_3601_Feet_Intl)
zone: 0
datum: nad83harn
ellipsoid: grs80
north: 588219.90693215
south: 536993.58817534
west: 7524575.13218961
east: 7561596.20977101
nsres: 2561.31593784
ewres: 1851.05387907
rows: 20
cols: 20
cells: 400
   I want to understand why the nsres is now 2561+ feet, the ewres now 1851+
feet, and the numbers of rows and columns has decreased so drastically.
Looking forward to learning,
Rich
zone: 0
ellipsoid: grs80
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
zone: 0
datum: nad83harn
ellipsoid: grs80
rows: 20
cols: 20
cells: 400
1851+
Rich
grass-user mailing list
grass-user@.osgeo
https://grass.osgeo.org/grass73/manuals/g.region.html
you can set a location's resolution to whatever you want. all is in the
manual.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-question-about-raster-map-resolutions-tp5286992p5287009.html
The r.proj module has a flag to get the new resolution settings when reprojection data from one LOCATION to another. Before reprojecting the map from ** unknown (default: WGS84) ** to nad83harn, try r.proj -g. Then use those parameters to set the region in the new CRS/LOCATION. That will leave you with the same number of row and columns in the new projection. Then you’ll need to do r.proj again to get the raster reprojected with these new region settings.
zone: 0
ellipsoid: grs80
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
zone: 0
datum: nad83harn
ellipsoid: grs80
rows: 20
cols: 20
cells: 400
Rich
grass-user@lists.osgeo.org
Micha Silver
Arava Drainage Authority
+972-523-665918
zone: 0
ellipsoid: grs80
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
zone: 0
datum: nad83harn
ellipsoid: grs80
rows: 20
cols: 20
cells: 400
1851+
Rich
grass-user@.osgeo
If it is about raster reprojection, there are hints in the r.proj manual
about region settings before applying r.proj.
E.g.
A simple way to do this is to check the projected bounds of the input map in
the current location's projection using the -p flag. The -g flag reports the
same thing, but in a form which can be directly cut and pasted into a
g.region command. After setting the region in that way you might check the
cell resolution with "g.region -p" then snap it to a regular grid with
g.region's -a flag. E.g. g.region -a res=5 -p. Note that this is just a
rough guide.
A more involved, but more accurate, way to do this is to generate a vector
"box" map of the region in the source location using v.in.region -d. This
"box" map is then reprojected into the target location with v.proj. Next the
region in the target location is set to the extent of the new vector map
with g.region along with the desired raster resolution (g.region -m can be
used in Latitude/Longitude locations to measure the geodetic length of a
pixel). r.proj is then run for the raster map the user wants to reproject.
In this case a little preparation goes a long way.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-question-about-raster-map-resolutions-tp5286992p5287020.html
zone: 0
ellipsoid: grs80
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
zone: 0
datum: nad83harn
ellipsoid: grs80
rows: 20
cols: 20
cells: 400
1851+
Helmut Kudrnovsky:
E.g.
g.region command.
Some observation: `-g` prints out in shell style, suitable for
`eval`uating. The `eval` utility, for example, constructs a
command, from the given arguments (here, the ouput of `g.region -g`)
which is then executed by the shell. See for example
https://grasswiki.osgeo.org/wiki/Shell_scripting#Using_output_from_GRASS_modules_in_the_script.
A ready to copy-n-paste form is obtained via `-f` (this is a recent
addition by Moritz during the code sprint in Bonn).
Maybe the `-f` flag would be a useful addition to `r.proj` as well.
Nikos
rough guide.
best regards
Helmut
zone: 0
ellipsoid: grs80
nsres: 3
ewres: 3
rows: 15360
cols: 10002
cells: 153630720
zone: 0
datum: nad83harn
ellipsoid: grs80
rows: 20
cols: 20
cells: 400
1851+
Helmut Kudrnovsky:
E.g.
g.region command.
AFAIR, the -g flag in r.proj already outputs flat format.
Moritz
manual.
Helmut,
   I've read the manual, several times. But it does not tell me why I see a
difference in the two regions by re-projecting the data from the source.
Thank you,
Rich
Then you'll need to do r.proj again to get the raster reprojected with
Micha,
   Thank you. I did not recognize the value of coordinating resolutions when
re-projecting data. I'll back up and re-do all the data today.
Much appreciated,
Rich
in the current location's projection using the -p flag. The -g flag
reports the same thing, but in a form which can be directly cut and pasted
into a g.region command. After setting the region in that way you might
check the cell resolution with "g.region -p" then snap it to a regular
grid with g.region's -a flag. E.g. g.region -a res=5 -p. Note that this is
just a rough guide.
the region in the target location is set to the extent of the new vector
map with g.region along with the desired raster resolution (g.region -m
can be used in Latitude/Longitude locations to measure the geodetic length
of a pixel). r.proj is then run for the raster map the user wants to
reproject. In this case a little preparation goes a long way.
Helmut,
   Thank you very much. This expansion of Micha's explanation is really
valuable and I greatly appreciate it. I wasn't aware of this need and
process the last time (years ago) I had a need to reproject data. Source
data in recent projects were all in the same projection and appropriate to
the area studied.
Rich
`eval`uating. The `eval` utility, for example, constructs a command, from
the given arguments (here, the ouput of `g.region -g`) which is then
Nikos,
   Thank you.
Rich
pasted
is
just a rough guide.
vector
length
Helmut,
the area studied.
Rich
grass-user@.osgeo
It's copy /paste from the manual. So the manual is your best friend. :wink:
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-question-about-raster-map-resolutions-tp5286992p5287104.html
