[GRASS-user] A Script that only selects raster inside a polygon
Greetings
I want to develop a script that crops a raster in order to only have the pixels that are located inside a vector polygon. Which functionality shall I use?
Thanks
pedro
Pedro Roma:
There is probably a more elegant solution, but this will do:
g.region vect=your_vector
v.to.rast input=your_vector output=your_vector_rasterized use=val
r.mask input=your_vector_rasterized
r.mapcalc "clipped_raster=original_raster"
r.mask -r
Hope this helps,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/A-Script-that-only-selects-raster-inside-a-polygon-tp5567368p5567467.html
Pedro Roma:
Marcello Gorini:
(comment of minor importance I guess... the above needs "value=" to be fed
with a value of course).
r.mask -r
Marcello,
honestly, it's very nice to see how you stepped up from 0 to 100 within almost
zero time :slight_smile:
(...watch out for curves and steep slopes :-p)
All the best, Nikos
Cheers, Nikos
Pedro Roma:
Marcello Gorini:
Nikos:
...forgot (that the) default (is) "value=1" which will work just fine. :stuck_out_tongue:
Nikos
> r.mask -r
Pedro Roma:
Marcello Gorini:
Nikos:
r.mask -r
Marcello,
almost
Thanks a lot for your comments Nikos! I am just trying to make up for lost
time due to my "Windows point-and-click" past life :slight_smile:
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/A-Script-that-only-selects-raster-inside-a-polygon-tp5567368p5568572.html
Hi
I Would like to thank to Nikos and Marcello for the reply to my question.
Instead of using r.mask (I’m not a big fan of r.mask) can I cross my v.to.rast raster(composed by 1 and nulls) and my raster file?
Or this is not a good idea
Thanks
Pedro
Pedro Roma wrote:
Instead of using r.mask (I'm not a big fan of r.mask) can I cross my
r.mapcalc "outrast = if(isnull(maskrast),null(),inrast)"
