Hello,
I’m trying to produce an elevation model with this interpolation method.
So while the v.surf.rst doing the work i’m suddenly (just before the green bar reaches the end) getting this message “out of memory”.I must say that my area of interest is little big. Any suggestions ? Thanks in advance…
What kind of machine are you using? i.e. how much RAM do you have? and how
high of a data density do you have?
In the mean time, try running v.surf.rst on a smaller region. Also have a look
at the segmax parameter.
Dylan
On Monday 07 August 2006 14:32, thefamilyguy933 a wrote:
Hello,
I'm trying to produce an elevation model with this interpolation method.
So while the v.surf.rst doing the work i'm suddenly (just before the green
bar reaches the end) getting this message "out of memory".I must say that
my area of interest is little big. Any suggestions ? Thanks in advance...
Χρησιμοποιείτε Yahoo!
Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων http://login.yahoo.com/config/mail?.intl=gr
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
My Pc is a pentium 4 3.00 cpu ghz with 2gb of Ram.
I tryied with a smaller region and all went ok but Unfortunately i must work in
the region i noted before. I'm working with 20m contours. The problem remains.
Please help...
