I know the "from" and "to" syntax for the mv command. But I
am not a command line Master! I'm getting confused with
"sed" command.
Anyway,
yes, I am trying Markus' approach (GRASSNews.vol.3).
Both ways no luck.
I will give it a shot with NOAA maybe. Is it high-res?
Thanks.
On Thu, 10 Jan 2008 21:17:04 -0800 (PST)
Hamish <hamish_b@yahoo.com> wrote:
nikos.alexandris wrote:
> I still didn't find a way to import coastlines from the
> VMAP data base.
> I tried to look after the:
> mv: missing destination file operand after `.'
> error message but I can't figure it out.
there is a problem within the script. Probably an unset
$VARIABLE, or
bad quoting.
"mv" needs two arguments, a 'from' and a 'to' file. If
one is a
$VARIABLE and is unset, it is passed blank to the mv
command and the mv
command then complains that it didn't get enough info.
(Just a guess, I don't know how the '.' part of the error
fits)
> I don't need necessarily to convert into a shapefile.
> Anybody that has done it recently? I really need this
in
> order to convert it to a raster and use it as a MASK.
Sorry I haven't read earlier in this thread. Did you try
the method
given in Markus's article in GRASS Newsletter vol 3?
An alternate coastline can be obtained by the NOAA
coastline extractor.
See the v.in.mapgen help page. Then v.type and
v.centroids to make the
line into an area. (boundary+centroid = area)
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Nikos Alexandris - Ph.D. Candidate
Department of Remote Sensing
and
Landscape Information Systems
(FeLIS)
Faculty of Forestry and Natural Environment
Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697
Fax. +49 (0) 761 203 3701
Skype: Nikos.Alexandris
Address: Tennenbacher str. 4
D-79106 Freiburg i. Br.
Germany
