i'm trying to use r.neighbors with the weight option along with the sum function;
maibe i do not get how it's supposed to work...
this is what i'm using:
Neighborhood operation: sum
Neighborhood size: 3
Weight:
0 0 0
-1 0 1
0 0 0
and i get a null result.
You get a null result if the total number of values is zero. For a
weighted sum, "the total number of values" is the sum of the weights,
which in this case is zero.
I'd suggest that r.mfilter may be more appropriate for implementing
discrete convolution (FIR) filters.
with r.mfilter.fp i got the expected result,
anyway i find a bit strange it does not works
with r.neighborhood…
Date: Tue, 3 Jun 2014 06:11:44 +0100
To: royroge@outlook.com
CC: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] About r.neighbors weight usage
weighted sum, “the total number of values” is the sum of the weights,
I’d suggest that r.mfilter may be more appropriate for implementing
