I have some issues using the r.out.GMT addons, using grass63-cvs.
Basically, the addons works, and I get two files, a file.grd a file.cpt, which I
use with the following commands to directly display with GMT (4.1.2):
grdimage file.grd -R689000/710000/4895000/4920000 -Jx1:100 -Cfile.cpt -P -V
map.ps
Unfortunately, I then get this error message:
grdimage: Allocates memory and read data file
grdimage: Not a netCDF file [slp_GMT.grd]
I was wondering why this happens, given that the addons should produce a
compatible grd file to be used with GMT.
Is it that I'm missing something? Can you help me?
By the way, I also used v.out.GMT, aand it works fine, except for the fact that
I got a compatibility error message, which was solved after I deleted the first
line of the xy file produced by the addons, which only contained the '>'
character.
Hope you can help,
thanks,
Marco
This message was sent using IMP, the Internet Messaging Program.
On Fri, Oct 20, 2006 at 10:22:27AM +0200, mrigotti@agrsci.unibo.it wrote:
>map.ps
You need to add a map type to the file name. If the original map is in
CELL format, "grdimage file.grd=2 ...", otherwise "gridimage file.grd=1
..." is correct.
character.
v.out.gmt supports multiple polylines using the '>' flag. You have to
specify -M option for psxy to work.
If you're not sure, use -p flag when running [rv].out.gmt to see GMT
commands.
Huidae
Hope you can help,
thanks,
Marco
grassuser mailing list
grassuser@grass.itc.it
> Hi,
> which I use with the following commands to directly display with GMT
> (4.1.2):
> -V
> >map.ps
..." is correct.
> fact that I got a compatibility error message, which was solved after I
> deleted the first line of the xy file produced by the addons, which only
> contained the '>' character.
commands.
Huidae
> Hope you can help,
> thanks,
> Marco
Nice to see that there has been some development in connecting GRASS and GMT .
I have some updates for the r.out.gmt script which make the output grid files
directly readable by all GMT apps. Perhaps Hamish and I can work out a good
time to merge the changes. As far as I know, there are still some issues with
the automatic creation of CPT files, used by GMT for color lookup.
I wasn't aware of the v.out.GMT script - I will have to take a look, as it is
something that I have been meaning to do for quite some time now.
I'll post back with details once my changes are merged into the r.out.gmt
script.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
