[GRASS-user] About Spatial PCA in GRASS
I am interested to run the spatial-mode PCA on raster time series. In R it is implemented as an ‘EOF’ function in spacetime Package. The function transposes the raster stack and applies ‘prcomp’ function. I would like to know if there is any possible way to implement i.pca similar to this approach.
Interestingly, I found a very good tutorial on GRASS raster time series at https://grasswiki.osgeo.org/wiki/Temporal_data_processing/GRASS_R_raster_time_series_processing This includes the example using spacetime package to read GRASS raster time series into R.
I would very much appreciate any support on this.
Thank you.
Shiva
Shiva Khanal
University of Western Sydney, Australia
Hi Shiva,
El jue., 12 jul. 2018 a las 2:45, Shiva Khanal (<shiva_khanal@hotmail.com>) escribió:
there’s also an alternative way to export raster time series from GRASS that was not there at the moment of creating the wiki: the add-on t.rast.out.xyz [0] that produces a table with xy coordinates and all dates in columns. You can then import that into R, transpose and run prcomp, EOF or others. Do you want it for gap-filling?
If you dare to implement EOF in GRASS, please go ahead!! I will be very happy to test and provide feedback, I’ve been wishing for such a thing (and also DINEOF) for a while :slight_smile:
Maybe the devs can provide hints and advice on how to address it.
Best,
Vero
[0] https://grass.osgeo.org/grass74/manuals/addons/t.rast.out.xyz.html
Hi Vero,
Thank you for your response. The only issue I have running the EOF in R is the data size.
My raster stack is a MODIS time series.
stk
class : RasterStack
dimensions : 2423, 2470, 5984810, 690 (nrow, ncol, ncell, nlayers)
resolution : 499.9339, 499.9718 (x, y)
extent : -85163.44, 1149673, 5656775, 6868207 (xmin, xmax, ymin, ymax)
coord. ref. : NA
names : X2001.01.01, X2001.01.09, X2001.01.17, X2001.01.25, X2001.02.02, X2001.02.10, X2001.02.18, X2001.02.26, X2001.03.06, X2001.03.14, X2001.03.22, X2001.03.30, X2001.04.07, X2001.04.15, X2001.04.23, …
min values : 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, …
max values : 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, …
The size of raster stack is ~8 mb.
object.size(stk)
8699416 bytes
But, when I try to export it to a table, it becomes several GBs, which is too much for my desktop. (Though, my desktop has ~32 GB RAM with 8 cores)
Therefore, I am looking for the possibility of running i.pca but on transposed raster time series stack.
I am motivated by the nice grasswiki on PCA which compares the i.pca outputs against the R equivalent functions.
https://grasswiki.osgeo.org/wiki/Principal_Components_Analysis
I would appreciate any help on this.
Shiva
Hi Shiva,
Best,
Vero
