[GRASS-user] Accentuating/adding topography to a raster image?
We're trying to add in a bit of topographic shading/illumination into an
image, and I was hoping to get some feedback on what algorithms work the
best? I tried a hillshade approach in ENVI, was pretty unimpressed with it.
Any suggestions for a GRASS approach? Run r.sun and do some sort of pixel
weighting?
--j
Jonathan A. Greenberg, PhD
NASA Postdoctoral Researcher
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Phone: 415-794-5043
AIM: jgrn3007
MSN: jgrn3007@hotmail.com
I use this approach:
d.his h=your_map i=aspect
or
d.his h=your_map i=r_shaded_relief
or run nviz and set the light source :wink:
jachym
weighting?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
grassuser mailing list
grassuser@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Jonathan Greenberg napisa?(a):
r.shaded.relief ?
Maciek
This is also automatically done in the GUI. Just put your shaded relief map
into the basemap field and your image into the drape map field.
Display and presto, you have a topographically shaded image.
You can also do this in nviz for an even more dramatic effect. Use a DEM
(not shaded relief) as a basemap/elevation map and use your image as a color
map for the topography.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Sat, 12 Aug 2006 12:27:33 +0200
To: Jonathan Greenberg <jgreenberg@arc.nasa.gov>
Cc: 'GRASS user list' <grassuser@grass.itc.it>
Subject: Re: [GRASS-user] Accentuating/adding topography to a raster image?
or
jachym
weighting?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
My main problem is the dem and image are both about 1.5 gb each -- am I
likely to run into problems with this?
Never played with nviz before, looks like I'll be trying it out tonight!
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
-----Original Message-----
From: Michael Barton [mailto:michael.barton@asu.edu]
Sent: Saturday, August 12, 2006 10:54 AM
To: Jachym Cepicky; Jonathan Greenberg
Michael
phone: 480-965-6213
fax: 480-965-7671
image?
or
jachym
it.
pixel
weighting?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
what about resample your resolution?
    g.region res=*MORE*
result could be still printable, but it would not be so big
jachym
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Jachym Cepicky <jachym.cepicky@centrum.cz>
image?
> Hi,
> or
> jachym
it.
pixel
>> weighting?
>> --j
>> MS 242-4
>> Phone: 415-794-5043
>> AIM: jgrn3007
>> _______________________________________________
> Jachym Cepicky
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
We are printing this out for a 9 foot by 5 foot wall installation, so we
need to keep the resolution (as it stands it will output about a 130 dpi,
the range for the printer is 100 to 200 dpi).
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
From: Jachym Cepicky [mailto:jachym.cepicky@centrum.cz]
Sent: Saturday, August 12, 2006 11:13 AM
    g.region res=*MORE*
jachym
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
image?
map
color
Michael
phone: 480-965-6213
fax: 480-965-7671
image?
> Hi,
> or
> jachym
an
the
with
it.
pixel
>> weighting?
>> --j
>> MS 242-4
>> Phone: 415-794-5043
>> AIM: jgrn3007
> Jachym Cepicky
> GPG:
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
DEFINITELY drop your resolution before running nviz (or even making a shaded
relief map) unless you want to take all night to display stuff. This will
have a much bigger effect than the size of the image per se.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Sat, 12 Aug 2006 20:12:48 +0200
    g.region res=*MORE*
jachym
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Michael
phone: 480-965-6213
fax: 480-965-7671
image?
or
jachym
it.
pixel
weighting?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Hi Jonathan, others,
I have done somehting similar for very large datasets: i.e. a 30m DEM
for CA, then AZ, and then finally NV.
Here is what I did, all without memory problems: all sizes are approx.
1. patch together my DEM data (2.5 Gb)
2. compute shaded rel. via r.shaded.relief (1.5Gb)
3. patch 30m landsat tiles and create *nice* color composites 4x (1.5Gb)
4. blend shaded relief and landsat composite 3x (2gb)
5. re-composite blened output channels (4Gb)
6. tile resulting raster for speedy access via mapserver
do this for each state...
a quick example can be seen here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/253?size=_original
or on the actual online soil survey itself:
http://casoilresource.lawr.ucdavis.edu/drupal/node/27
note that CA and NV look the best, still working on re-doing AZ with
the i.landsat.rgb module:
http://casoilresource.lawr.ucdavis.edu/drupal/node/159
the actual computations tool several hours, so i would leave the
machine to do its work overnight, usually to find the output the next
morning. I would estimate at least 2 days of computer time (2x Xeon
2.8 GHz) for something this size.
hope that is helpful,
Dylan
Michael
phone: 480-965-6213
fax: 480-965-7671
> g.region res=*MORE*
> jachym
>> --j
>> MS 242-4
>> Phone: 415-794-5043
>> AIM: jgrn3007
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>> image?
>>> Hi,
>>> or
>>> jachym
>> it.
>> pixel
>>>> weighting?
>>>> --j
>>>> MS 242-4
>>>> Phone: 415-794-5043
>>>> AIM: jgrn3007
>>> Jachym Cepicky
>>> OFFICE:
>>> GDF-Hannover
>>> Mengendamm 16d
>>> 30177 Hannover
>>> Germany
> Jachym Cepicky
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
The resolution of the region will have no effect on the resolution of the
screen for graphic output from GRASS, unless the region resolution (i.e.,
columns and rows) is less than the width and height of the screen in pixels.
If you are exporting this map (e.g., to a tif), then the resolution of the
region will have an effect on the resolution of the export.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Sat, 12 Aug 2006 11:17:07 -0700
To: 'Jachym Cepicky' <jachym.cepicky@centrum.cz>
Subject: RE: [GRASS-user] Accentuating/adding topography to a raster image?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
    g.region res=*MORE*
jachym
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
image?
map
color
Michael
phone: 480-965-6213
fax: 480-965-7671
image?
or
jachym
an
the
with
it.
pixel
weighting?
--j
MS 242-4
Phone: 415-794-5043
AIM: jgrn3007
Jachym Cepicky
GPG:
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
