This question was asked in http://gis.stackexchange.com/questions/28061/how-to-access-vector-coordinates-in-grass-gis-from-python/28100#28100 and I propose a solution with v.out.ascii.
But is there a better solution ?
My solution (a single line → L 7 1)
test = grass.read_command(“v.out.ascii”, input=“linevector”, format=“standard”)
result = test.split(“\n”)
import re
for line in result:
if re.findall(r’^.[0-9]+.',line):
print line
206643.21517601 125181.18058576
201007.33432923 121517.8555206
208615.77587567 118699.91687157
199034.77765775 115036.59058769
200725.54321492 111936.8560102
192835.30987687 107428.14794157
and
coords =
for line in result:
coords.append(line.strip().split(" "))
[[‘206643.21517601’, ‘125181.18058576’], [‘201007.33432923’, ‘121517.8555206’], [‘208615.77587567’, ‘118699.91687157’], [‘199034.77765775’, ‘115036.59058769’], [‘200725.54321492’, ‘111936.8560102’], [‘192835.30987687’, ‘107428.14794157’], [‘192835.30987687’, ‘107428.14794157’], [‘206643.21517601’, ‘125181.18058576’], [‘201007.33432923’, ‘121517.8555206’], [‘208615.77587567’, ‘118699.91687157’], [‘199034.77765775’, ‘115036.59058769’], [‘200725.54321492’, ‘111936.8560102’], [‘192835.30987687’, ‘107428.14794157’], [‘192835.30987687’, ‘107428.14794157’]]
If you want, you can create a new point layer from the coordinates (solution of Yvan Marchesini in http://osgeo-org.1560.n6.nabble.com/How-one-can-find-the-starting-and-end-point-of-a-line-in-a-vector-file-or-how-one-can-connect-two-lie-td4542252.html)
