[GRASS-user] Accuracy assessment
I want to apply the r.kappa operator in order to perform the Accuracy assessment. The problem is that I have one GeoTIFF input as the thematic map, and the referenced input is in a .shp file. Converting the .shp file to a GeoTIFF seams to be problematic. Is there any way to use the r.kappa operator with the .shp file as second input? Or maybe you have other ideas how to overcome this situation.
Thanks in advanced,
Danut
Hi Danut,
You can import the shapefile to grass with v.in.ogr. Then u should convert the vector to a raster with v.to.rast, using the same categories as for ur image. Then you should be able to perform r.kappa.
Stefan
Gesendet mit BlackBerry® Webmail von Telekom Deutschland
From: “Danut Mihon [via OSGeo.org]” <[hidden email]>
Date: Fri, 15 Jun 2012 09:49:20 -0700 (PDT)
To: Stefan Sylla<[hidden email]>
Subject: Accuracy assessment
Thanks in advanced,
Danut
grass-user mailing list
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Accuracy-assessment-tp4981775.html
To start a new topic under Grass - Users, email [hidden email]
To unsubscribe from Grass - Users, click here.
NAML
View this message in context: AW: Accuracy assessment
