[GRASS-user] Acoustic noise
I am trying to find something in GRASS to use for acoustic noise evaluation.
I found a paper of Brovelli e Scuratti that says they developed a module in GRASS but I can not find the module or the source code. Does anybody knows if this software is open source? and if it will be where I can download it?
Thanks in advance,
Silvia
Hi Silvia,
I've tried to get some answers from the authors but without any success.
I see that You are Italian, please send them questions in their own language maybe You'll then get some information and, please, tell the results also in this list !
Best regards,
Kari
Silvia Franceschi wrote:
Thanks in advance,
Silvia
Kari Salovaara
Hanko, Finland
evaluation.
download it?
Thanks in advance,
Silvia
Their site is
http://geomatica.como.polimi.it/software/
If it uses GRASS functions, it has to be published (since GPL).
The easiest way will be to write to the authors directly...
View this message in context: http://www.nabble.com/Acoustic-noise-tf4710810.html#a13475087
> evaluation.
> download it?
Their site is
The GPL doesn't require that you "publish" derivative works, only that
any distribution complies with the GPL (i.e. you provide or offer to
provide source code, and licence the code under the GPL).
It's permitted to create derivative works and never release them, or
to only give copies to specific people. If you give copies to others,
they are permitted to redistribute them further, but are not required
to do so.
IOW, the GPL doesn't require distribution, it just prohibits
prohibiting distribution.
Anyone who has a copy of a GPL'd work can distribute it (or not) as
they see fit, but someone who doesn't have a copy has no specific
right to obtain one.
evaluation.
Thanks in advance,
Silvia
Their site is
There are GRASS modules available for download on that page:
"Comandi di GRASS sviluppati dal Laboratorio di Geomatica"
Moritz
