[GRASS-user] Add category for each centroid
I have a vector map with several polygons each having a centroid. All
polygons have the same category:
v.db.select bb
cat|ART
1|1
Now, I want to have a category for each polygon or each centroid. With
that, I hope to be able to access each polygon separately. I tried
everything I can find the in the manual, but apparently not the correct
command....
Any idea?
Thanks a lot!
Sebastian
having a centroid. All polygons have the same
category:
> v.db.select bb
cat|ART
1|1
or each centroid. With that, I hope to be able to
apparently not the correct command....
Any idea?
remove all cats, then re-apply new ones with v.category:
v.category option=del type=centroid
v.category option=add type=centroid cat=1 step=1
Hamish
category:
v.db.select bb
cat|ART
1|1
Any idea?
Thanks for the hint!
After the commands above (and this what I missed), the categories have
to be inserted in the table:
v.to.db option=cat
Sebastian
