[GRASS-user] Add command layer problem
2012/11/14 Aldo Clerici <aldo.clerici@unipr.it>:
Surely due to my scarce practice with the wxpython GUI
(grass-6.4.svn_src_snapshot_2012_09_15) I’m not able to insert a command in
the Layer Manager tree. I click the ‘Add grid or vector labels overlay’
button in the Layer Manager, then the ‘Add command layer’ option. A blank
layer is added in the Layer Manager. I type the command, for example d.rast
geology (Spearfish data), in the layer, then Enter, but the map is not
displayed in the Map Display, not even by using the Display and Render
buttons (the Render option is on anyway) . Where did I go wrong?
command map layer is something like artefact from TCL/TK GUI and not
really used by most of users I would guess. You need to type the name
of the first parameter, so `d.rast map=geology`. This should be fixed
in r53811 (6.4.3svn), where `d.rast geology` should work. Testing
welcomed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
