Hi there,
I try to find a way to give every line segment in my vector file a db entry.
I've create 3 lines and split them into 50m segments. Now I want to do
several calculations with it. Therefore I need for each segment a row in the
db.
*How can I create a entry for each segment?*
v.info split_lines
Number of lines: 598
v.db.select split_lines
cat
1
2
3
I would appreciate if someone can explain me what I do wrong, I tried
already everything I could found without success (eg. v.dissolve,
v.category, v.centroids, and others)
regards Valentin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Add-DB-entries-to-vector-line-after-v-split-tp6922423p6922423.html
