[GRASS-user] Adding options to grass.run_command
I'm writing my first GRASS Python script and am having trouble adding
options to commands that I want to run. For example, the following
works:
grass.run_command("r.in.xyz", input=directory+'/'+file,
output=rainraster, fs=',', x=2, y=1)
but this doesn't:
grass.run_command("r.in.xyz", --overwrite, input=directory+'/'+file,
neither does this:
grass.run_command("r.in.xyz --overwrite", input=directory+'/'+file,
How can I get this to work, or is there a better way of doing it using
a command other than grass.run_command?
Thanks
Hanlie
2010/9/3 Hanlie Pretorius <hanlie.pretorius@gmail.com>:
better `input = os.path.join(directory, file)`
but this doesn't:
neither does this:
should be `overwrite = True` instead `--overwrite`
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Thanks :slight_smile:
2010/9/3, Martin Landa <landa.martin@gmail.com>:
but this doesn't:
neither does this:
Martin
Martin Landa wrote:
> but this doesn't:
> neither does this:
Likewise for "quiet" and "verbose".
Any normal (single-dash) flags must specified via "flags=...", e.g.:
  r.something -a -b -c ...
becomes:
  grass.run_command("r.something", flags="abc", ...)
