[GRASS-user] Additional notes g.extension problems on Mac
Hello,
I just wanted to post some addtional information about using g.extension on Mac OSX (10.6.8) with GRASS 7.0.svn48327.
This follows probably this bug report: http://trac.osgeo.org/grass/ticket/1406
I tried to install the r.fuzzy AddOn with following command:
g.extension extension=r.fuzzy
I get back following lines which include the problem:
GRASS_ADDON_PATH has more items, using first defined - '/Users/admin/Library/Application Support/GRASS/7.0/Modules/bin'
Fetching 'r.fuzzy' from GRASS-Addons SVN (be patient)...
A r.fuzzy/r.fuzzy.set
A r.fuzzy/r.fuzzy.set/local_proto.h
A r.fuzzy/r.fuzzy.set/shape.png
A r.fuzzy/r.fuzzy.set/r.fuzzy.set.html
A r.fuzzy/r.fuzzy.set/main.c
A r.fuzzy/r.fuzzy.set/boundary.png
A r.fuzzy/r.fuzzy.set/fuzzy.c
A r.fuzzy/r.fuzzy.set/Makefile
A r.fuzzy/r.fuzzy.set/set.png
A r.fuzzy/r.fuzzy.logic
A r.fuzzy/r.fuzzy.logic/local_proto.h
A r.fuzzy/r.fuzzy.logic/main.c
A r.fuzzy/r.fuzzy.logic/r.fuzzy.logic.html
A r.fuzzy/r.fuzzy.logic/Makefile
A r.fuzzy/r.fuzzy.logic/logic.c
A r.fuzzy/r.fuzzy.system
A r.fuzzy/r.fuzzy.system/flood.map
A r.fuzzy/r.fuzzy.system/helpers.c
A r.fuzzy/r.fuzzy.system/local_proto.h
A r.fuzzy/r.fuzzy.system/flood.rul
A r.fuzzy/r.fuzzy.system/rule_parser.c
A r.fuzzy/r.fuzzy.system/main.c
A r.fuzzy/r.fuzzy.system/system.c
A r.fuzzy/r.fuzzy.system/f_result.png
A r.fuzzy/r.fuzzy.system/fuzzylogic.c
A r.fuzzy/r.fuzzy.system/io.c
A r.fuzzy/r.fuzzy.system/map_parser.c
A r.fuzzy/r.fuzzy.system/Makefile
A r.fuzzy/r.fuzzy.system/r.fuzzy.system.html
A r.fuzzy/Makefile
Checked out revision 48639.
Compiling 'r.fuzzy'...
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/bin.i386-apple-darwin10.8.0
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include/grass
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/lib
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/driver
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/driver/db
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/fonts
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/docs
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/man
mkdir -p /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/tools
make -C r.fuzzy.set || echo /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/997.0/r.fuzzy/r.fuzzy.set >> /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/error.log
test -d OBJ.i386-apple-darwin10.8.0 || mkdir -p OBJ.i386-apple-darwin10.8.0
gcc -g -O2 -arch i386 -arch x86_64 -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -o OBJ.i386-apple-darwin10.8.0/fuzzy.o -c fuzzy.c
fuzzy.c:1:27: error: grass/glocale.h: No such file or
directory
In file included from fuzzy.c:2:
local_proto.h:5:26: error: grass/raster.h: No such file or
directory
local_proto.h:6:23: error: grass/gis.h: No such file or
directory
local_proto.h:36: error: expected ‘)’ before ‘cell’
fuzzy.c:4: error: expected ‘)’ before ‘cell’
directory
directory
directory
lipo: can't figure out the architecture type of: /var/folder
s/kd/kdoDqWZZEbOKmz4Jf+VB4++++TM/-Tmp-//ccNLMHls.out
make[1]: *** [OBJ.i386-apple-darwin10.8.0/fuzzy.o] Error 1
logic.c:1:23: error: grass/gis.h: No such file or directory
logic.c:2:27: error: grass/glocale.h: No such file or
directory
make -C r.fuzzy.logic || echo /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/997.0/r.fuzzy/r.fuzzy.logic >> /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/error.log
gcc -g -O2 -arch i386 -arch x86_64 -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -o OBJ.i386-apple-darwin10.8.0/logic.o -c logic.c
make -C r.fuzzy.system || echo /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/997.0/r.fuzzy/r.fuzzy.system >> /Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/error.log
gcc -g -O2 -arch i386 -arch x86_64 -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -I/Users/admin/Documents/GRASS-Source/grass-7.0.svn_src_snapshot_2011_09_17/dist.i386-apple-darwin10.8.0/include -o OBJ.i386-apple-darwin10.8.0/fuzzylogic.o -c fuzzylogic.c
In file included from logic.c:3:
local_proto.h:6:26: error: grass/raster.h: No such file or
directory
directory
directory
s/kd/kdoDqWZZEbOKmz4Jf+VB4++++TM/-Tmp-//cccBLTrh.out
make[1]: *** [OBJ.i386-apple-darwin10.8.0/logic.o] Error 1
In file included from fuzzylogic.c:1:
local_proto.h:5:23: error: grass/gis.h: No such file or
directory
directory
local_proto.h:7:27: error: grass/glocale.h: No such file or
directory
local_proto.h:107: error: expected specifier-qualifier-list
before ‘RASTER_MAP_TYPE’
local_proto.h:117: error: expected specifier-qualifier-list
before ‘DCELL’
local_proto.h:137: error: expected specifier-qualifier-list
before ‘FCELL’
local_proto.h:186: error: expected ‘)’ before ‘cell’
fuzzylogic.c:3: error: expected ‘)’ before ‘cell’
directory
directory
directory
before ‘DCELL’
before ‘FCELL’
s/kd/kdoDqWZZEbOKmz4Jf+VB4++++TM/-Tmp-//ccYze1gs.out
make[1]: *** [OBJ.i386-apple-darwin10.8.0/fuzzylogic.o]
Error 1
Installing 'r.fuzzy'...
make: *** No rule to make target `install'. Stop.
Installation failed, sorry. Please check above error messages.
(Wed Oct 5 12:49:31 2011) Command finished (37 sec)
(Wed Oct 5 13:01:33 2011)
Maybe this helps you analysing the problem. Is there any plan when g.extension should work on Mac as well as on Windows?
Thank you
Best regard
Johannes
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
7.0.svn48327.
the root cause of the two are unrelated AFAICT.
command:
directory
directory
directory
it can't find the grass include header files.
William has applied a Mac fix to the shell script version in
grass 6.4svn, can you try that? (ARCH_INC and ARCH_LIBPATH)
this has not been set in the grass 7 yet; if the grass 6 method
works it should be ported over. please let us know.
Windows?
As far as I know it doesn't work well on Windows due to the
commonality of spaces in path names, the build system we rely
on doesn't like that, and there's not much we can do to change
the situation. Mac and Linux should be made to work most of the
time, but the hard truth is that g.extension is never going to
work 100% for end-users. the big question is how far into the
90%s can we get?
Hamish
Hello again!
There are some good news to tell!
I just tried as Hamish recommended to use g.extension on
the GRASS 6.4SVN ... and it seems to work!!
My system:
Mac OS 10.6.8
GRASS 6.4.2svn48574
I installed the r.fuzzy AddOn as an example. There was only one error
message during installation:
ERROR: G_getenv(): Variable LOCATION_NAME not set
(the whole output below)
After the installation I called r.fuzzy from the command console
in the GRASS GUI and the r.fuzzy GUI popped up, so it seems
that it works... There is just no html-help in the gui but I can
call the help with r.fuzzy --help.
So I am looking forward that this feature will be ported to GRASS 7.0.
As I don't know how porting works etc. maybe a stupid question, but when do you think g.extension will be working on GRASS 7.0SVN? In the meanwhile I probably have to compile GRASS 7.0 together with the AddOns.
Just to come back to the Windows-g.extension issue: I understand the problem with the spaces in the paths and believe that this can be really difficult in programming. Anyway from the point of a normal GRASS GIS user: A lot of people in my surrounding are interested in some very useful GRASS GIS AddOns (r.stream.* and an AddOn I am developing at the moment (fish dispersal)). But nearly all of them are working on Windows so it is a kind of barrier to them to have a look into the usefulness of such GRASS GIS AddOns as they are not willing to learn how to compile it. Anyway I think this is of course a known issue and will be at least easier to solve in future. I am really happy about the features of GRASS GIS, its AddOns but also its helpful community!
cheers
Johannes
PS: Here the output of the successful Add-On installation in GRASS6.4SVN:
Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
A r.fuzzy/local_proto.h
A r.fuzzy/shape.png
A r.fuzzy/main.c
A r.fuzzy/boundary.png
A r.fuzzy/description.html
A r.fuzzy/fuzzy.c
A r.fuzzy/Makefile
A r.fuzzy/set.png
U r.fuzzy
Checked out revision 48643.
Compiling <r.fuzzy>...
/Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Gras
s.make:422: warning: overriding commands for target
`/Users/admin/Documents/GRASS-
Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin'
s.make:413: warning: ignoring old commands for target
/Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Modu
le.make:25: warning: overriding commands for target
`install'
/Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Rule
s.make:90: warning: ignoring old commands for target
`install'
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/include/grass
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/etc
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/driver
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/driver/db
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/fonts
gcc -I/Applications/GRASS-6.4.app/Contents/MacOS/include -I/Users/admin/Library/GRASS/6.4/Modules/bin/include -I/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/include -g -O2 -arch i386 -arch x86_64 -I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include -DPACKAGE=\""grassmods"\" -I/Applications/GRASS-6.4.app/Contents/MacOS/include -I/Users/admin/Library/GRASS/6.4/Modules/bin/include -I/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/include -o OBJ.i386-apple-darwin10.8.0/fuzzy.o -c fuzzy.c
gcc -I/Applications/GRASS-6.4.app/Contents/MacOS/include -I/Users/admin/Library/GRASS/6.4/Modules/bin/include -I/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/include -g -O2 -arch i386 -arch x86_64 -I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include -DPACKAGE=\""grassmods"\" -I/Applications/GRASS-6.4.app/Contents/MacOS/include -I/Users/admin/Library/GRASS/6.4/Modules/bin/include -I/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/include -o OBJ.i386-apple-darwin10.8.0/main.o -c main.c
gcc -L/Applications/GRASS-6.4.app/Contents/MacOS/lib -L/Users/admin/Library/GRASS/6.4/Modules/bin/lib -L/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/lib -arch i386 -arch x86_64 -arch i386 -arch x86_64 -o /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin/r.fuzzy OBJ.i386-apple-darwin10.8.0/fuzzy.o OBJ.i386-apple-darwin10.8.0/main.o -lgrass_vect.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_dbmiclient.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_dgl.6.4.2svn -lgrass_dig2.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_rtree.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_linkm.6.4.2svn -lgrass_rtree.6.4.2svn -lgrass_dig2.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_rtree.6.4.2svn -lgrass_dgl.6.4.2svn -lgrass_rtree.6.4.2svn -lgrass_linkm.6.4.2svn -lgrass_dbmiclient.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -framework GDAL -L/Library/Frameworks/GEOS.framework/Versions/3/unix/lib -lgeos -lgeos_c -lgrass_dbmiclient.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lz -lz
ld: warning: directory
'/Users/admin/Library/GRASS/6.4/Modules/bin/lib' following
-L not found
ld: warning: directory '/Users/admin/Documents/GRASS-
Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/lib'
following -L not found
-L not found
`install'
`install'
`install'
`install'
make htmlcmd
make /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html HTMLSRC=/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin/r.fuzzy
if [ "/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin/r.fuzzy" != "" ] ; then GISRC=/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/demolocation/.grassrc64 GISBASE=/users/admin/documents/GRASS-Source/grass-6.4.svn_src_snapshot_2011_10_01/dist.i386-apple-darwin10.8.0 PATH="/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin:$PATH" DYLD_LIBRARY_PATH="/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin:/Applications/GRASS-6.4.app/Contents/MacOS/lib:/Applications/GRASS-6.4.app/Contents/MacOS/lib:/Users/admin/Library/GRASS/6.4/Modules/lib:/Library/GRASS/6.4/Modules/lib" LC_ALL=C /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin/r.fuzzy --html-description < /dev/null | grep -v '</body>\|</html>' > r.fuzzy.tmp.html ; true ; fi
/Applications/GRASS-6.4.app/Contents/MacOS/tools/mkhtml.sh r.fuzzy ; mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html ; /usr/bin/install -c -m 644 r.fuzzy.tmp.html /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html ; fi done 2> /dev/null ; true
make mancmd
make /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1/r.fuzzy.1 MANSRC=/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html
mkdir -p /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.2svn sh /Applications/GRASS-6.4.app/Contents/MacOS/tools/g.html2man/g.html2man /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1/r.fuzzy.1 1
`install'
`install'
`install'
`install'
Converting: /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html to /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1/r.fuzzy.1
INST_NOW= make
make htmlcmd
make[4]: `/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html' is up to date.
make mancmd
make[4]: `/Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1/r.fuzzy.1' is up to date.
`install'
`install'
`install'
`install'
`install'
`install'
`install'
`install'
`install'
`install'
`install'
`install'
Installing <r.fuzzy>...
/usr/bin/install -c /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/bin/r.fuzzy /Users/admin/Library/GRASS/6.4/Modules/bin/bin/
/usr/bin/install -c -m 644 /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/docs/html/r.fuzzy.html /Users/admin/Library/GRASS/6.4/Modules/bin/docs/html/
/usr/bin/install -c -m 644 /Users/admin/Documents/GRASS-GIS/Test_Location/PERMANENT/.tmp/Johannes-Snow-Leopard.local/70683.0/dist.x86_64-apple-darwin10.0/man/man1/r.fuzzy.1 /Users/admin/Library/GRASS/6.4/Modules/bin/man/man1/
`install'
`install'
Installation of <r.fuzzy> in </Users/admin/Library/GRASS/6.4/Modules/bin> complete.
(Wed Oct 5 16:35:50 2011) Command finished (15 sec)
-------- Original-Nachricht --------
Datum: Wed, 5 Oct 2011 06:27:55 -0700 (PDT)
Von: Hamish <hamish_b@yahoo.com>
An: Johannes Radinger <JRadinger@gmx.at>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] Additional notes g.extension problems on Mac
> 7.0.svn48327.
> command:
> directory
> directory
> directory
> Windows?
90%s can we get?
Hamish
grass-user mailing list
