Two tables: 'sites' contains the ID and geographic coordinates;
'waterchem' contains the ID and water chemistry data. The latter table is a
sub-set of the former.
I want to display only those sites for which chemistry data are available.
In postgres I write,
SELECT DISTINCT(w.site) FROM waterchem AS w
WHERE EXISTS (SELECT s.name FROM sites AS s
WHERE w.site = s.name);
Can I submit this same query within GRASS and have the returned sites
displayed by location? If so, is there a preferred method for doing so?
Rich
Just use everything after the first WHERE as argument for the 'where' parameter of d.vect (or any other module with a where parameter).
Moritz
Moritz,
Thank you.
Rich
Two tables: ‘sites’ contains the ID and geographic coordinates;
‘waterchem’ contains the ID and water chemistry data. The latter table is a
Just use everything after the first WHERE as argument for the ‘where’ parameter of d.vect (or any other module with a where parameter).
Sorry to butt in…
Can you have a where=“” argument that references a table other than the actual vector map’s table?
I tried with i.e. v.extract (to select records from a vector based on a related column in another, separate table, and I wasn’t successful.
Is there any way to connect a vector map to a PG view ?
Micha
