Hi Becky,
if you want to have it super easy, download and install
gvSIG OADE 2010:
http://www.oadigital.net/software/gvsigoade
When you run the installer, make sure to tick all available
extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
Full instructions are here:
ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
A quickstart guide for gvSIG is also available:
ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
... but surely, someone at your department is already using gvSIG?
You can then run a large number of GRASS modules directly via
the SEXTANTE graphical user interface.
r.cva and r.promincence are already included.
Best,
Ben
On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
Hi GRASS-Users
Apologies for cross-posting.
My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
command 'gem6' is not recognised
command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
ERROR: Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
I have an older version of GRASS (GRASS 6.3.0). From here the command
'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:ERROR: Compilation failed for these module(s):
/private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
/private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
Run 'make' manually in each module's directory for details.
make: *** [default] Error 1I've now run make in both modules (I think), but I still get the same error message. I also don't understand why the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help gratefully received!
Thanks
Beckygrass-user@lists.osgeo.org
grass-user mailing list
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
