[GRASS-user] Advice needed - quickest way to create a mosaic
I need some advice on the quickest way to create a mosaic.
I have sucessfully used the example from the r.patch manual page:
MAPS=`g.mlist type=rast sep=, pat="map_*"`
g.region rast=$MAPS
r.patch in=$MAPS out=mosaic
I have 115 1 degree ASTER tiles that I want to mosaic together before
re-projecting with r.proj.
My 1st attempt was to run r.patch with a list of all 115 tiles.
It didn't seem to progress - the progress stuck at 0% for about 5 minutes. I
killed the process.
My 2nd attempt was to create strips for each degree of latitude and then
patch the strips together.
There are about 10 tiles in each strip. Each strip took a few minutes.
Patching the 14 strips together took more than 1 hour (2.3GHz Intel Dual
Core + 4Gb RAM).
Should I have waited for my 1st attempt to finish?
Or is it more efficient to create strips, and then patch the strips
together?
Is there another faster method?
I have tried using gdalwarp, but with large areas it eats up all my RAM,
starts swapping and
effectively hangs the machine.
Peter
View this message in context: http://n2.nabble.com/Advice-needed-quickest-way-to-create-a-mosaic-tp4731125p4731125.html
On Sun, Mar 14, 2010 at 10:45 AM, geep999 <geep999@yahoo.co.uk> wrote:
g.region rast=$MAPS
killed the process.
To tile 115 maps needs WAY more that 5 minutes, maybe a few days depending
on the map size, computer speed, RAM etc.
I am used to wait days to obtain (large) mosaiks, using gdalwarp.
Core + 4Gb RAM).
together?
Sincerely, I have no idea if working in chunks is faster.
starts swapping and effectively hangs the machine.
I usually use gdalwarp for mosaiking like this:
------- snip ------------------------
#!bin/sh
# mosaik DTM tiles
RES=5
OUTFILE=dtm_${RES}m_UTM_WGS84.tif
SHADED=`basename $OUTFILE .tif`
INDIR=/geodata2_originals_raid5/dem_tiles/
INPUT="$INDIR/dtm*.tif"
# GDAL_CACHEMAX --config GDAL_CACHEMAX 500 -wm 500
CACHE="--config GDAL_CACHEMAX 3000 -wm 3000"
gdalwarp $CACHE $INPUT $OUTFILE
mv $OUTFILE dtm.tmp
gdal_translate -a_srs utm32N.prj dtm.tmp $OUTFILE
rm -f dtm.tmp
gdaladdo $OUTFILE 2 4 8 16 32 64
# gdaldem hillshade
gdaldem hillshade $OUTFILE ${SHADED}_shaded.tif
gdaladdo ${SHADED}_shaded.tif 2 4 8 16 32 64
date
echo "Generated $OUTFILE"
------- snap ------------------------
Works well even on a portable computer...
> patch the strips together?
I believe it will be considerably faster. much less empty space
to search through.
Hamish
