[GRASS-user] Advice on importing V5 data sets?
Is there a conversion utility, guide or other resource for importing old data to V7.8? This is over 50GB of data and I need to recover it.
I’ve tried viewing it in QGIS desktop and opening the mapset in V7.8 but the data simply isn’t recognised at all. Googling hasn’t helped.
Thanks for any suggestions
On Tue, Jun 22, 2021 at 4:33 PM brendon wolff-piggott
Is it raster or vector data, or both?
I've tried viewing it in QGIS desktop and opening the mapset in V7.8 but the data simply isn't recognised at all. Googling hasn't helped.
Please describe a bit more what you try to achieve: Your "old data"
have been generated in which GRASS GIS version?
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Sorry, thought I had answered yesterday. It is both vector and raster. Created in GRASS 5.1 (not sure of .x number).
I would like to import the data into PostGIS, so I can access it in GRASS or QGIS.
I have quite a lot of the original shape files that I could import again, but not the raster data and DEMs created from it.
Please describe a bit more what you try to achieve: Your “old data”
Markus Neteler, PhD
On Thu, Jun 24, 2021 at 10:06 AM brendon wolff-piggott
I finally found back this page and updated the links therein:
https://grasswiki.osgeo.org/wiki/Upgrading_GRASS_database
It contains:
Upgrading the GRASS database from older to recent GRASS versions
1.1 Migrating from GRASS 4 to GRASS 5
1.2 Migrating from GRASS 4 to GRASS 6
1.3 Migrating from GRASS 5 to GRASS 6
1.4 Migrating from GRASS 6 to GRASS 7
That should be doable, since conversion tools are included.
I would expect that the raster maps from GRASS GIS 5 can be opened in
any later version without problems.
If not, please send the error message.
Markus Neteler, PhD
Le 24 juin 2021 10:06:27 GMT+02:00, brendon wolff-piggott <mytekmail@gmail.com> a écrit :
or QGIS.
If all you want is to get the data out of a GRASS GIS database, another option would be to simply install GRASS 5 and then export the data: https://grass.osgeo.org/about/history/releases/ (see 2004 for 5.x source code).
Moritz
Thanks for all the advice. I’m still tinkering as other projects came up in the meantime but it looks promising
On Fri, Jun 25, 2021, 8:51 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
or QGIS.
Moritz
