[GRASS-user] Again: Problem with WMS-Services
Hi list members,
I wrote to the list a few weeks ago with no answers to my problem.
So again here is my problem again:
I have a problem importing WMS-Services into GRASS. Here is the command
and the description of the error I got:
##The command which has been issued on grass command line
r.in.wms -d -p output=DEM_WMS
mapserver=http://10.3.1.12/cgi-bin/mapserv?map=/data/umn/pmapper-3.0.1/config/default/demo_wms.map
layers=DEM_WMS srs=EPSG:4326 format=geotiff wmsquery=version=1.1.1
maxcols=1024 maxrows=1024 folder=/home/uleopold/tmp 'wgetoptions=-c -t 5
--user-agent=MSIE5.5' method=nearest v=1 --overwrite
##The error message:
wms.download 'requestfile=/home/uleopold/tmp/DEM_WMS_.wget'
'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
Downloading tiles
cat: /home/uleopold/tmp/DEM_WMS_.wget: No such file or directory
All tiles downloaded successfully
r.in.gdalwarp -c -p 'output=DEM_WMS' 'method=nearest' 's_srs=EPSG:4326'
ERROR: Required parameter <input> not set:
    (Raster file or files to be imported. If multiple files are
specified they will be patched together.).
In software like QGIS and ArcGIS the WMS-Service is working very well.
It seems that there is aproblem with the input data that is piped to
gdalwarp.
Any ideas...?
cheers
Christian
command and the description of the error I got:
1/config/default/demo_wms.map layers=DEM_WMS srs=EPSG:4326
format=geotiff wmsquery=version=1.1.1 maxcols=1024 maxrows=1024
folder=/home/uleopold/tmp 'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
Downloading tiles
's_srs=EPSG:4326'
gdalwarp.
Any ideas...?
Are you using Ubuntu and GRASS 6.2.1? Ubuntu uses "dash" as it's /bin/sh
instead of Bash. r.in.wms and friends used bash-specific tricks in them.
This has since been fixed and will appear in future releases of GRASS.
You can recompile from CVS yourself (or just grab the updated scripts*),
or you can edit the existing r.in.wms, r.in.gdalwarp, r.tileset, and wms.*
scripts by hand: change #!/bin/sh to #!/bin/bash in the first line of
each file.
[*] download latest "releasebranch_6_2" versions from:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/
Hamish
Building from yesterday's cvs,
r.in.wms and r.in.gdalwarp(/Applications/GRASS-6.3.app/Contents/Resources/etc/r.in.wms) still have #!/bin/sh, r.tileset has #!/bin/bash
I still got the bug I reported some time ago
WARNING: xml2 NOT avaliable
sed: 1: "s/<\/Title>//i
": bad flag in substitute command: 'i'
sed: 1: "s/<\/*.*\/*\/*>//i
sed: 1: "s/<Name>\s*\(\w*\)/~\1~ ...": bad flag in substitute command: 'i'
sed: 1: "s/<\/Name>\n//ig
sed: sed: 1: "s/<Layer .*>/LAYER:/i
1: "s/<\/Style>//i
sed: 1: "s/<Title>\(.*\)<\/Title ...": bad flag in substitute command: 'i'
sed: 1: "s/<Style>\n*\s*\(\w*\)/ ...": bad flag in substitute command: 'i'
sed: 1: "s/<\/Layer.*>//i
#!/bin/sh
Downloading tiles
's_srs=EPSG:4326'
gdalwarp.
Any ideas...?
each file.
Hamish
grassuser mailing list
grassuser@grass.itc.it
You can recompile from CVS yourself (or just grab the updated scripts*), or
scripts by hand: change #!/bin/sh to #!/bin/bash in the first line of each
file.
Hamish
Yes, that was the problem. Thank you for your help, Hamish
Christian
(try yet again using today's CVS; "g.message" was broken in a few places)
#!/bin/bash
r.in.wms was changed to not need bash. But it is easier to change the
old installed version to use bash (by changing that top line) than it is
to explain about all the needed changes.
r.tileset uses all sorts of bash array tricks which I have no idea how
to fix. So that is the only one I've changed to #!/bin/bash. In the other
WMS scripts I have replaced the bash specific code and kept as #!/bin/sh.
Hamish
instead of Bash.
To be exact, only Ubuntu > 6.06.1 uses dash. All previous, until and
including Dapper 6.06.1 use bash.
Maciek
