[GRASS-user] again Raster names
in a script, which I executed under GRASS 6.4 under Ubunto, I included
commands like r.in.gdal input=/media/.../filename output=surfac_ereflection.
1. An error message illegal filename <surfac_ereflection.1>, <illegal
character showed up. When I typed this command into the window underneath
the output window, it worked fine. I also run the script using data
on a FAT32 formatted partition as well as data in the /home directory.
The files to be imported are MODIS data.
Best regards
Niels
Dr. Niels Thevs
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4132
Fax: +49-3834-86-4114
WEB-Mailer der Uni-Greifswald ( http://www.uni-greifswald.de/ )
How are you creating the script? Are you sure that invalid characters
(e.g. carriage return, non-breaking space, etc) aren't being introduced?
Try to create a minimal script which demonstrates the problem, then
post it as a binary attachment.
