[GRASS-user] Airborne LiDAR data strip adjustment
Hello to all using GRASS,
I received ALS data, which is with overlapping strips in both directions, east-west and north-south. Is it available some algorithm to do a strip adjustment in GRASS GIS or any other software, so I can build cleared DEM (without overlapping data)?
Greetings,
Adrian Kirilov
Hello to all,
Ok, I just found out that this is not necessary! My data are already pre-processed, so it’s applied strip adjustment. I have to divide it into subsets and merge the data, because now it’s in form of strips. I guess the right method is using ‘g.region’ when importing the strips and then combine them by exporting a vector map with ‘v.out.ascii’ and re-import the whole map and interpolating a surface. What do you think?
Greetings,
Adrian Kirilov
Greetings,
Adrian Kirilov
