Thanks for the feedback. I ended up converting longitude to 0-360 as Brent suggested. Its fairly easy to
do with R. I included the little R script that I wrote in case anyone else might find it useful. In general, R
is good for manipulating shapefiles.
======R script follows============
##Use this script to pull a state out of the national shapefile that came
##from http://nationalatlas.gov. It also converts lon from
##-180,+180 to 0-360, and also demonstrates how to work with shapefiles
#boundingBox returns a matrix of points representing a bounding box of a submitted user polygon
boundingBox <- function(xy){
yMin <-min(xy[,2]); yMax <-max(xy[,2]);
xMin <-min(xy[,1]); xMax <-max(xy[,1]);
bb<-c(xMin,yMin, xMax, yMax);
return(bb);
library(maptools) #load the library
fName="statesp020"; #name of shapefile that needs sorting and trimming
fOut="02"; #output file name, AK fips code=02
ST="Alaska" #state name in dbf file
shp <- read.shape(paste(fName,".shp",sep="")) #read in the original shapefile
dbf <- read.dbf(paste(fName,".dbf",sep="")) #read in the original dbf file
cat("Wait while making a polyList \n")
shapes <- Map2poly(shp,region.id=NULL)
keep=dbf[,"STATE"]==ST
sub=subset(shapes,keep)
dbf2 = dbf[keep,]
#convert from +180,-180 to 0-360 (only needed for Alaska)
for(i in 1:length(sub)){
vec=sub[i][[1]][,1]<0;
sub[i][[1]][vec,1]= 360 + sub[i][[1]][vec,1]
attr(sub[i][[1]],"bbox") = boundingBox(sub[i][[1]])
centroid=attr(sub[i][[1]],"centroid")$x
if(centroid<0)attr(sub[i][[1]],"centroid")$x=360+centroid
write.polylistShape(sub,dbf2,fOut,factor2char = TRUE)
cat("\n its done \n")
============end of R script=================
Gary Sherman wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
If you are only interested in Alaska an perhaps part of Canada and Russia, you could always project the data to Alaska Albers:
- -PROJ_INFO-------------------------------------------------
name : Albers Equal Area
proj : aea
datum : nad83
a : 6378206.4
es : 0.006768657997291279
lat_1 : 55
lat_2 : 65
lat_0 : 50
lon_0 : -154
x_0 : 0
y_0 : 0
no_defs : defined
- -PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
On Mar 15, 2007, at 1:43 PM, Brent Wood wrote:
Paul Van Deusen wrote:
Welcome to my world
Working in the maritime area around New Zealand, 180 is an issue I deal with regularly
I suggest you add 360 to every longitude < 0. This moves the break to zero degrees instead of 180.
You can also use a variety of local projections to avoid the issue.
There is a parameter in the CVS version of proj4 to set the central meridian, defaults to zero, but a reprojection to WGS84 (EPSG:4326) with explicit parameters, & the central meridian of 18- works well....
Brent Wood
I'm trying to read in the state boundary shapefile from http://nationalatlas.gov. However, the Aleutian Islands
cross the 180th parrallel, so longitude goes from +180 to -180 at that point. I end up with the end of the
Aleutian Islands getting disconnected. What is the solution? I used v.in.ogr and set up a location using the information that came
with the shapefile. See spatial information below..
Spatial_Reference_Information:
Horizontal_Coordinate_System_Definition:
Geographic:
Latitude_Resolution: 0.000278
Longitude_Resolution: 0.000278
Geographic_Coordinate_Units: Decimal degrees
Geodetic_Model:
Horizontal_Datum_Name: North American Datum of 1983
Ellipsoid_Name: GRS1980
Semi-major_Axis: 6378137
Denominator_of_Flattening_Ratio: 298.257222
grassuser mailing list
grassuser@grass.itc.it
- -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
"We work virtually everywhere"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (Darwin)
iD8DBQFF+e+01zKuzV6goTgRAjjrAJ9Fp1YYqi03Ad44d2bKgMa39HTn2ACgpFPX
TuQxiQQJ+vIxZDwXwaNH/2s=
=qi5X
-----END PGP SIGNATURE-----
Paul Van Deusen
NCASI
600 Suffolk St. Fifth Floor
Lowell, MA 01854
978-934-1948
