[GRASS-user] align two maps, same projection - different centers
I have a raster that I received from a colleague that has a different center northing parameter from another map in the same projection. All the rest of the region and projection information are correct. I think what I need to do is to re-project the new raster to match the center northing parameter of the old map. Which command should I be using to accomplish this within GRASS? Or, should I be using an external tool like gdalwarp on the original img file (before I import it into GRASS?
Kirk
Here is the output of r.region for the raster with the wrong center, and the output of v.region for a vector with the correct center:
GRASS 6.4.1 (northcentralus_albersequalarea):~ > g.region -pc rast=mnwimifnfftgk7wt175v3_250m
projection: 99 (Albers Equal Area)
zone: 0
datum: nad83
ellipsoid: grs80
north: 2960848
south: 2087348
west: -122110
east: 1141890
nsres: 250
ewres: 250
rows: 3494
cols: 5056
cells: 17665664
center easting: 509890.000000
center northing: 2524098.000000
GRASS 6.4.1 (northcentralus_albersequalarea):~ > g.region -pc vect=nw212
zone: 0
datum: nad83
ellipsoid: grs80
north: 1322833.8573
south: 647305.3646
west: 6150.4319
east: 1003361.9406
nsres: 250.01054504
ewres: 249.99035064
rows: 2702
cols: 3989
cells: 10778278
center easting: 504756.186250
center northing: 985069.610950
