[GRASS-user] alter table - sqlite
hi list!
i'm working with sqlite and i want to add a column to the table of 'vector1'. i
tried several possibilities (v.db.addcol, db.execute; double, real,...) but i
got always the same error:
e.g.
v.db.addcol map=vector1 columns="area_size REAL" layer=1
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "ALTER": syntax error
FEHLER: Error while executing: "ALTER TABLE vector1 ADD COLUMN
        area_size REAL
ERROR: Cannot continue (problem adding column).
e.g.
echo "ALTER TABLE vector1 ADD COLUMN area_size DOUBLE PRECISION" | db.execute
but: if i use the sqlitebrowser and execute the statement in the 'execute sql
tab' like this, it works(!):
however, i need a solution adding a column using shell scripting & sqlite. what
do i wrong? has anybody had a similar problem?
thanks,
martin
Hi Martin,
I am using GRASS 6.1.CVS, and it works with the following command
v.db.addcol map=block_extrakt columns="neu INT"
I did not specify layer in this command (but when I tried layer=1, I also got
the same error message). However, you need not to specify the layer option,
as
"v.db.addcol adds one or more column(s) to the attribute table connected to a
given vector map. It automatically checks the connection for the specified
layer." (see g.manual v.db.addcol for example). Additionally, the "layer"-tag
needs to be written before the columns-tag.
I hope that this might help you.
Am Donnerstag 10 August 2006 pH:07:17 nachmittags/abends schrieb Martin
Rutzinger:
hi list!
'vector1'. i tried several possibilities (v.db.addcol, db.execute; double,
real,...) but i got always the same error:
e.g.
        area_size REAL
e.g.
db.execute
sql tab' like this, it works(!):
what do i wrong? has anybody had a similar problem?
thanks,
martin
grassuser mailing list
grassuser@grass.itc.it
hi wolfgang!
i tried it also without the layer option, but this did not help. i also use
GRASS 6.1.CVS and SQLITE-CVS.
may be there is something wrong with SQLITE? which version of SQLITE is
supported/recommended to use with GRASS?
but thanks,
martin.
Zitat von wqual <wolfgang.qual@gmx.net>:
Hi Martin,
as
Rutzinger:
> hi list!
> e.g.
> area_size REAL
> e.g.
> db.execute
> thanks,
> martin
I just tried, no problem... I have sqlite-3.3.4-6 installed.
Do you use a recent 6.1.CVS?
On Thu, Aug 10, 2006 at 06:09:49PM +0200, Martin Rutzinger wrote:
hi wolfgang!
but thanks,
martin.
> Hi Martin,
> as
> Rutzinger:
> > hi list!
> > e.g.
> > area_size REAL
> > e.g.
> > db.execute
> > thanks,
> > martin
> > _______________________________________________
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
