[GRASS-user] an error during running of module r.bioclim
help me please to correct this mistake
r.bioclim tmin=tmin1_17@PERMANENT,tmin2_17@PERMANENT,tmin3_17@PERMANENT,tmin4_17@PERMANENT,tmin5_17@PERMANENT,tmin6_17@PERMANENT,tmin7_17@PERMANENT,tmin8_17@PERMANENT,tmin9_17@PERMANENT,tmin10_17@PERMANENT,tmin11_17@PERMANENT,tmin12_17@PERMANENT tmax=tmax1_17@PERMANENT,tmax2_17@PERMANENT,tmax3_17@PERMANENT,tmax4_17@PERMANENT,tmax5_17@PERMANENT,tmax6_17@PERMANENT,tmax7_17@PERMANENT,tmax8_17@PERMANENT,tmax9_17@PERMANENT,tmax10_17@PERMANENT,tmax11_17@PERMANENT,tmax12_17@PERMANENT output=result
Unknown module parameter “keyword” at line 18
Unknown module parameter “keyword” at line 19
Calculating monthly averages from min and max
ERROR: Sorry, is not a valid parameter
ERROR: Value out of range for parameter
Legal range: rast,rast3d,vect,oldvect,asciivect,icon
,labels,sites,region,region3d,group,view3d,all
BIO1 = Annual Mean Temperature …
ERROR: Raster map not found
Invalid map <result.bio01.10012>
Parse error
ERROR: parse error
ERROR: An error occurred while running r.mapcalc
(Fri Sep 4 17:23:14 2015) Command finished (1 min 29 sec)
regards
Albert Saribekyan.
On Fri, Sep 4, 2015 at 3:36 PM, Albert Saribekyan
r.bioclim
output=result
Unknown module parameter "keyword" at line 18
Unknown module parameter "keyword" at line 19
You need to run r.bioclim in GRASS GIS 7 (is it possible that you try
it in GRASS GIS 6?).
Best
I am already using GRASS GIS 7, see the attachment file
Albert Saribekyan.
9/4/2015 11:00:26 PM пользователь Markus Neteler (neteler@osgeo.org) написал:
> r.bioclim
> output=result
Best
(attachments)
Screenshot from 2015-09-08 11:56:32.png
On Tue, Sep 8, 2015 at 9:58 AM, Albert Saribekyan
Your installation must be rather "old" because you still have the old
login screen.
Since the beginning of 2015 is looks like this:
https://grasswiki.osgeo.org/wiki/File:GRASS_GIS_70_startup.png
You can see the precise version also in the Menu
Help >> About system
or
g.version -g
Please consider to update.
