a friend of mine wants (needs?) to determine the angle between segments
in an ESRI polyline (line vector feature). As there does not seem to be
an easy way in ArcGIS 9.2, I thought about askeng here:
Is there way of calculating these angles between the different line
segments in grass?
Centre of Excellence for Invasion Biology
Natural Sciences Building
Office Suite 2039
Stellenbosch University
Main Campus, Merriman Avenue
Stellenbosch
South Africa
between segments in an ESRI polyline (line vector feature).
As there does not seem to be an easy way in ArcGIS 9.2, I
different line segments in grass?
first split the poly line up into individual segments with
v.split vertices=1
then upload the slope of each line into the attribute table with
v.to.db option=azimuth
finally compare the angle between each connecting segments.
thanks a lot - that sounds reasonably easy - might be another happy
GRASS (ex-ESRI) user?
Rainer
v.split vertices=1
Office Suite 2039
Stellenbosch
South Africa
segments in grass?
If problem concerns stream network, try to use r.stream.angle exension
J.
