[GRASS-user] another database question grass 6.4.3
I have access to a machine running grass 6.4.3. I developed code using 6.4.2 which includes using the function v.out.org to export a vector file to a postgres database. However, in the new version, it seems that the PostgreSQL driver isn't included. Here's the relevant part of the output:
ERROR: value <PostgreSQL> out of range for parameter <format>
       Legal range: ESRI_Shapefile,MapInfo_File,TIGER,S57,DGN,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,PCIDSK,DXF,Geoconcept,GeoRSS,GPSTrackMaker,PGDump,GPSBabel,
Do I need to install something additional or was this left out intentionally?
Shaun
out intentionally?
The inclusion or exclusion of support for different DBs is
determined at build time. The good news is that the code you
wrote for 6.4.2 should work for all future 6.4.x without
needing any changes. The bad news is that whoever built 6.4.3
on that system will have to rebuild/replace it with a version
of 6.4.3(rc/svn) that was built with support for the Postgres
optional extra.
Hamish
ERROR: value<PostgreSQL> out of range for parameter<format>
out intentionally?
optional extra.
I always thought that the inclusion of specific drivers in v.*.ogr and r.*.gdal depends on the compilation of GDAL/OGR, not on the compilation of GRASS.
@Shaun: what does 'ogrinfo --formats' show ?
Moritz
On Mon, Apr 8, 2013 at 9:40 AM, Moritz Lennert
out intentionally?
optional extra.
GRASS.
Yes, in this case OGR needs to be recompiled with PostgreSQL support.
There is no need to recompile or reinstall GRASS.
Markus M
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
