[r.in.wms]
Hamish wrote:
no geotiff support. set format= to one of the above.
I tried in a WGS84 lat/lon loc:
g.region n=50:30N s=47:15N w=9E e=13:45E res=0:00:30
r.in.wms mapserver="$SERVER" layer=TK50
out=TK50_Bavaria format=png -git seemed to work, but I only got a blank map. Maybe you
will have better luck. Using "-g" I got a
"(c) Bayerische ..." in the image, without "-g" I didn't. shrug.
Richard wrote:
I've never been able to decide whether "blank raster syndrome" in
r.in.wms is at the client or the server. In some cases, I guess it's
the server because things rectify themselves if you come back tomorrow.
In this case I'm pretty sure it's the server. As above, in at least one set of blank images I see the (c) watermark which comes through ok. Also with r.in.wms you can look in the $LOCATION/wms_downloads/ dir and see the raw download images before any client processing. all blank.
In other cases, adjusting the region parameters - zoom in to a smaller
area, and use a finer resolution - fixes the problem.
I took your suggestion and tried zooming in some. Success!
I would note that earlier when I was getting the blank image I did check the bounds layer's capabilities to make sure I was not exceeding the bounding box. So it seems to be matter of scale, not bounding box.
# LL/WGS84 location
SERVER="http://www.geodaten.bayern.de/ogc/getogc.cgi?"
g.region n=49:17N s=48:33N w=10:54:30E e=11:32:30E res=0:00:02
r.in.wms mapserver="$SERVER" layer=UK500 out=UK500_Bavaria.3 format=tiff
then you get a map of roads, place names, cities, etc.
(format=tiff looks more detailed than 8bit png, but png is way more efficient for empty files. shrug)
#zooming in more, DOP layer (2m aerial photo) looks good:
g.region n=49:12:02N s=49:04:20N w=11:03:26E e=11:11:42E res=0:00:01
r.in.wms mapserver="$SERVER" layer=DOP out=DOP_Bavaria format=tiff
# and zooming even further the TK50 layer finally works
# TK50 is a similar feature map to UK500, including contours
g.region n=49:10:06N s=49:07:34N w=11:06:27E e=11:08:54E res=0:00:00.25
r.in.wms mapserver="$SERVER" layer=TK50 out=TK50_Bavaria format=tiff
So yes, zooming helps.
The DOP layer draped over SRTM data would look very nice.
Hamish
ps- I have just added an option in SVN to store the capabilities file when using the -l flag.
