Hello,
I wonder what is the best way to append a vector map and his attribute data created with v.in.ascii ?
Thanks
Frank
Hello,
Thanks
Frank
Try:
v.patch -a
https://grass.osgeo.org/grass76/manuals/v.patch.html
(assuming attribute tables are equal).
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Frank David
Sent: fredag 26. oktober 2018 11:39
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] append data after a v.in.ascii import
Hello,
Thanks
Frank
grass-user mailing list
Hi Stephan,
If I add two vector in a new one with :
v.patch -c input=map1,map2 out=map3
I notice the map3 first cat start at 2 instead of 1, so all cat are shifted by one. Do you have an idea of the reason ?
If I append my map1 with map2 :
v.patch -c -a input=map2 output=map1 --overwrite it works well
Thank you
Frank
Le 26/10/2018 à 12:01, Stefan Blumentrath a écrit :
Hi, Try: v.patch -a [https://grass.osgeo.org/grass76/manuals/v.patch.html](https://grass.osgeo.org/grass76/manuals/v.patch.html) (assuming attribute tables are equal). Cheers Stefan -----Original Message----- From: grass-user [<grass-user-bounces@lists.osgeo.org>](mailto:grass-user-bounces@lists.osgeo.org) On Behalf Of Frank David Sent: fredag 26. oktober 2018 11:39 To: [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) Subject: [GRASS-user] append data after a v.in.ascii import Hello, I wonder what is the best way to append a vector map and his attribute data created with v.in.ascii ? Thanks Frank _______________________________________________ grass-user mailing list [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) [https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
I reply to myself,
I mistook, if I append, I see a cat shift too. The fisrt cat of the second map is shift by one. It's strange no ?
Frank
Le 26/10/2018 à 14:17, Frank David a écrit :
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
https://grass.osgeo.org/grass76/manuals/v.patch.html(assuming attribute tables are equal).
Stefan-----Original Message-----
From: grass-user<grass-user-bounces@lists.osgeo.org> On Behalf Of Frank David
To:grass-user@lists.osgeo.org
Subject: [GRASS-user] append data after a v.in.ascii importHello,
Thanks
Frank
https://lists.osgeo.org/mailman/listinfo/grass-user_______________________________________________
On Fri, Oct 26, 2018 at 2:26 PM Frank David <frank.david@geophom.fr> wrote:
I reply to myself,
second map is shift by one. It’s strange no ?
Suppose there is a feature with cat 1 in map A and a feature also with cat 1 in map B, but corresponding attribute values for cat 1 are different between map A and map B. In order to avoid such conflicts, v.patch shifts category values and updates the resultant attribute table accordingly, such that attributes for each feature are preserved.
Markus M
Frank
Hi Stephan,
shifted by one. Do you have an idea of the reason ?If I append my map1 with map2 :
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
Thank you Markus,
Is a feature could be created without a row data ?, because the two maps have been created with a v.in.ascii from a text file, so it means that one object by row has been created. For both of my two maps.
Frank
I reply to myself,
second map is shift by one. It’s strange no ?Suppose there is a feature with cat 1 in map A and a feature also with cat 1 in map B, but corresponding attribute values for cat 1 are different between map A and map B. In order to avoid such conflicts, v.patch shifts category values and updates the resultant attribute table accordingly, such that attributes for each feature are preserved.
Markus M
Frank
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
On Fri, Oct 26, 2018 at 7:17 PM Frank David <frank.david@geophom.fr> wrote:
Thank you Markus,
If you want to preserve attribute values, use v.patch -e, otherwise don’t use the -e flag, but then you might get duplicate category values.
v.patch -c should not work because -c is not a recognised flag. Which GRASS version did you use with v.patch -c?
Markus M
Frank
I reply to myself,
Markus M
Frank
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
Thank you Markus,
I’m sorry, when I wrote -c it was -e of course ! I’m using Grass 7.4.1
But even with -e, as I wrote, the cat of the second file is shift by one… (?)
I have used -e because I need to add my attribute table from both file. But I had imagine to keep cat relation with data, but it’s may be better to add a id field ? is there any way to increment a unique key automatically when data are appended ?
Frank
Markus M
Frank
I reply to myself,
Markus M
Frank
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
This is correct because it is needed to preserve attributes.
This unique key is automatically incremented when data are appended and attribute values need to be preserved. The unique key (more generally: the object identifier that determines to which category an object belongs) is the category value.
I am sure the output with shifted category values is exactly the output you want when preserving attribute values.
Markus M
Frank
Markus M
Frank
I reply to myself,
Markus M
Frank
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
Markus M
Thank you Markus.
I have to learn more about topology I think… I believe understand that cat value take care off all object of the vector map even those who are not connected to the attribute table… Thanks.
Frank
Frank
Markus M
Frank
I reply to myself,
Markus M
Frank
Hi Stephan,
Thank you
Frank
Try:
v.patch -a
Thanks
Frank
