2013/2/26 Markus Metz <markus.metz.giswork@gmail.com>:
BTW, v.transform simply transforms coordinates, it does not do any
cleaning. v.transform should actually work without topology, building
topology on the output is optional (in GRASS 7).
For this particular problem (georectifying overlapping polygons) there
is probably an easier solution outside GRASS. Maybe QGIS supports
coordinate transformation/rectification using GCPs?
Looks like you're right. I will try a newer version of GDAL / OGR. I
will also update GRASS, to use "v.rectify", so I can check the values
of the transformation matrix, and explore the possibility of working
without topology.
In QGIS, I could not find an equivalent function. Maybe it exist, but
I have looked very little. I know there is a plugin for GCP based
transformations, but it is for rasters. Anyway, some of the above
alternatives will surely solve my problem.
2013/2/26 Moritz Lennert <mlennert@club.worldonline.be>:
-1
I'm strongly opposed to that option. As you mention, this would
fundamentally undermine the data logic in GRASS.
To answer José's issue: If you want to keep on working in GRASS, you should
not try to do so with overlapping polygones.
Thanks Moritz, I hope fully understand all implications of this topic
someday! For now, I promise to not propose something like that
anymore.
If all you want to do in GRASS is v.transform, you should be able to import
with cleaning. Wherever there is overlap, you will get new polygones which
have all the category numbers of the original polygones. You can then
v.transform the file and if you need to get the original polygones you
should be able reconstruct them based on the common category numbers.
I considered doing this at first. But when I checked the maps
imported, I could not find all the information necessary to perform
the task. I will follow your instructions if only as an exercise to
learn a little more.
Thank you very much!
Jose
