[GRASS-user] Archiving GPM 3hr rainrate in GRASS
Has anyone here able to archive and load GPM dataset into GRASS? I
was able to get TRMM netcdf in my area of interest before, but I can't
find the tools to automate GPM downloads.
Thanks!
[0] http://www.nasa.gov/mission_pages/GPM/main/
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
On Mon, Nov 3, 2014 at 10:18 AM, maning sambale
Thanks!
They state
"All data are freely available through the NASA's Precipitation
Processing System at http://pps.gsfc.nasa.gov"
--> "Register and search for GPM and TRMM data, order custom subsets
and set up subscriptions using PPS Data Products Ordering Interface
(STORM)."
At time the server seems to be down?
Thanks Markus. Already registered and can access ftp. Unfortunately,
processed (L3) rainfall data will be released by Dec 2014.
Will just wait then. :slight_smile:
Thanks!
They state
(STORM)."
cheers,
maning
I’m coming back to that subject because the GPM datas are finally available since December 2014. The original data are stored in HDF5, which is supported by GDAL.
However, I had a problem with the geo-referencing of the data. It seems that the lat/long coordinates are flipped.
The problem seems to come from GDAL, as the HDF5 driver still don’t support GPM data:
http://www.gdal.org/frmt_hdf5.html
I’ve actually downloaded a regional extracts the data in NetCDF from a NASA website, although I can’t remember where exactly, as there are several services. Those data suffer from the same problem of inverted coordinates.
So I used the ncpdq from NCO package to fix the NetCDF directly, and a tiny Python script to batch process the files :
2014-11-06 5:15 GMT-06:00 maning sambale <emmanuel.sambale@gmail.com>:
was able to get TRMM netcdf in my area of interest before, but I can’t
Thanks!
They state
“All data are freely available through the NASA’s Precipitation
→ “Register and search for GPM and TRMM data, order custom subsets
(STORM).”
cheers,
maning
“Freedom is still the most radical idea of all” -N.Branden
grass-user mailing list
grass-user@lists.osgeo.org
Hello all,
I wrote a module that automatically download, import and register GPM
IMERG maps in GRASS.
You will need a NASA Earthdata Login to download the data. The code
can be found here:
https://bitbucket.org/lrntct/t.rast.in.gpm
For now, it is limited to IMERGHH data.
Hope it could help people working with those data.
Laurent
2015-03-19 10:50 GMT-06:00 Laurent C. <lrntct@gmail.com>:
I'm coming back to that subject because the GPM datas are finally available
supported by GDAL.
The problem seems to come from GDAL, as the HDF5 driver still don't support
GPM data:
I've actually downloaded a regional extracts the data in NetCDF from a NASA
website, although I can't remember where exactly, as there are several
#!/usr/bin/env python
from os import listdir
import subprocess
for input_file in listdir(main_path):
    output_file = input_file + '_fixed'
    subprocess.call(['ncpdq','-a', 'lat,lon', input_file, output_file])
After batch import the data in GRASS, maintaining the original name
including timestep, which looks like this:
3B-HHR.MS.MRG.3IMERG.20140619-S000000-E002959.0000.V03D
A Python script to register the maps in temporal framework:
import grass.script as grass
# retrieve the list of maps
maplist = grass.read_command('g.list', type = 'raster',
    pattern = '*IMERG*')
# turn result in a list
maplist = maplist.split()
file_name = 'gpm_timestamp.txt'
# creating the file containing the timepstamp
list_file = open(file_name,'w')
# iterate through the maps
for input_map in maplist:
    # split line to keep only the timestamp
    raw_ts = input_map.split('.')[4]
    # isolate the date
    raw_mapdate = raw_ts.split('-')[0]
    # put the date in form
    mapdate = raw_mapdate[:4] + '-' + raw_mapdate[4:6] + \
        '-' + raw_mapdate[6:]
    # isolate the start time
    raw_start_time = raw_ts.split('-')[1]
    start_time = raw_start_time[1:3] + ':' + \
        raw_start_time[3:5] + ':' + raw_start_time[5:]
    # isolate the end time
    raw_end_time = raw_ts.split('-')[2]
    # put the end time in form
    end_time = raw_end_time[1:3] + ':' + \
        raw_end_time[3:5] + ':' + raw_end_time[5:]
    # put timestamp in form
    timestamp = mapdate + ' ' + start_time + '|' + mapdate + \
        ' ' + end_time
    # format the whole line
    line = input_map + '|' + timestamp + '\n'
    # write line to the file
    list_file.write(line)
# close the file
list_file.close()
# register the maps in grass space_time dataset
grass.run_command('t.register', input = 'GPM_ZMCM', file = file_name)
Hope it will help other peoples having trouble using those data.
Laurent
>> Thanks!
> They state
> (STORM)."
> Markus
cheers,
maning
Hello Laurent
w00t! This new add-on sounds very nice! I’d like to do some testing. However, I tried to install it via g.extension and I get the following:
g.extension extension=t.rast.in.gpm url=https://bitbucket.org/lrntct/t.rast.in.gpm
Fetching <t.rast.in.gpm> from
<https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip> (be
patient)…
ERROR: Extension <t.rast.in.gpm> not found
Is it intended to install with g.extension?
thanks much!
Vero
2017-01-21 1:04 GMT+01:00 Laurent C. <lrntct@gmail.com>:
Hello all,
can be found here:
Laurent
supported by GDAL.
GPM data:
import subprocess
output_file = input_file + ‘_fixed’
subprocess.call([‘ncpdq’,‘-a’, ‘lat,lon’, input_file, output_file])
maplist = grass.read_command(‘g.list’, type = ‘raster’,
pattern = ‘IMERG’)
file_name = ‘gpm_timestamp.txt’
list_file = open(file_name,‘w’)
raw_ts = input_map.split(‘.’)[4]
isolate the date
raw_mapdate = raw_ts.split(‘-’)[0]
mapdate = raw_mapdate[:4] + ‘-’ + raw_mapdate[4:6] +
‘-’ + raw_mapdate[6:]
raw_start_time = raw_ts.split(‘-’)[1]
start_time = raw_start_time[1:3] + ‘:’ +
raw_start_time[3:5] + ‘:’ + raw_start_time[5:]
raw_end_time = raw_ts.split(‘-’)[2]
end_time = raw_end_time[1:3] + ‘:’ +
raw_end_time[3:5] + ‘:’ + raw_end_time[5:]
timestamp = mapdate + ’ ’ + start_time + ‘|’ + mapdate +
’ ’ + end_time
line = input_map + ‘|’ + timestamp + ‘\n’
close the file
list_file.close()
grass.run_command(‘t.register’, input = ‘GPM_ZMCM’, file = file_name)
Laurent
Thanks!
They state
(STORM).”
cheers,
maning
Hello Veronica,
Thanks for your interest. I've made some change to the code,
especially added a HTML file. I think it was the reason why
g.extension was failing.
The installation works now from a local folder. For some reason it
seems that g.extension fails to download the code from bitbucket.
If you download the repository of clone it first, it should work.
I'd be glad to hear your comments.
Laurent
2017-01-22 6:56 GMT-06:00 Veronica Andreo <veroandreo@gmail.com>:
Hello Laurent
w00t! This new add-on sounds very nice! I'd like to do some testing.
<https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip&gt; (be
patient)...
thanks much!
Vero
Hello all,
can be found here:
Laurent
> Hi all,
> available
> supported by GDAL.
> that
> support
> GPM data:
> NASA
> coordinates.
> tiny
> import subprocess
> # isolate the date
> ' ' + end_time
> # close the file
> list_file.close()
> Regards,
> Laurent
>> >> can't
>> >> Thanks!
>> > They state
>> > (STORM)."
>> > Markus
>> cheers,
>> maning
>> _______________________________________________
Hello Laurent,
Ok, I was able to install the add-on by cloning the repo and then installing from local folder:
git clone https://bitbucket.org/lrntct/t.rast.in.gpm.git
g.extension t.rast.in.gpm url=/home/veroandreo/software/t.rast.in.gpm/
I then installed nco toolbox, authorized NASA GESDISC DATA ARCHIVE and created the .netrc file.
man t.rast.in.gpm gave me the needed help :slight_smile: So I used the following and it worked as expected…
t.rast.in.gpm start_date=2016-01-01 end_date=2016-01-02 output=prueba_imerg
However… maybe it would be useful to add an example to the manual (?). And just a suggestion, though I’m not aware how difficult it might be: a ‘-l’ flag to list the available products/variables.
I like the module very much! Thanks!
Vero
2017-01-24 18:39 GMT+01:00 Laurent C. <lrntct@gmail.com>:
Hello Veronica,
Thanks for your interest. I’ve made some change to the code,
I’d be glad to hear your comments.
Laurent
Hello Laurent
patient)…
thanks much!
Vero
Hello all,
can be found here:
Laurent
available
supported by GDAL.
that
support
GPM data:
NASA
coordinates.
tiny
import subprocess
pattern = ‘IMERG’)
isolate the date
’ ’ + end_time
close the file
list_file.close()
Laurent
can’t
Thanks!
They state
(STORM).”
cheers,
maning
