[GRASS-user] Areas operations???
hello again,
I wrote a few days about a problem i had, and finally I said that i could
resolve it, but now I'm getting a headache more bigger XD
I have several maps vectorized, each one with several areas. These maps are
continuous and some of the areas are in two (or more) parts. I need to
vectorize it separated because of theis weight, but after that i need to
convert them into the same area.
I've been trying with v.patch, v.overlay, v.extrac and finally v.clean, but
i didn't get any useful results. Someone knows how can it be done??
again, sorry about my english
Andres
View this message in context: http://n2.nabble.com/Areas-operations----tp3294344p3294344.html
If I understand you mean that an area is "shared" across two or more
vector maps (files).
I need to vectorize it separated because of theis weight, but after
that i need to convert them into the same area.
The "usual" way is to:
* "v.patch" all vector maps in one vector map
* "v.clean" to clean potential duplicated boundaries (and other errors)
* "v.dissolve" by using a _common_ attribute (it is expected that the
areas that are "one" should have a common attribute defined in a column
of the attribute table of the vector map).
Check the manual of v.dissolve for an example. Hope this helps. If not
it would be useful to post exact description of what is to be done as
well as exact (copy-pasted) commands you tried.
Good Luck, Nikos
