[GRASS-user] areas with no centroid
After editing a map with wxgui I ended up with 39 areas and 38 centroids. How do I find and delete the area with no centroid?
I have tried many combinations of v.info, v.category, v.to.db, and visualizing with d.vect. If I use v.clean tool=rmarea with slowly increasing thresholds it gets rid of an area I want before it finds the one I don't so I don't think it's a sliver.
GRASS GIS 7.3.svn > v.info demo
Number of points: 0 Number of centroids: 38 Number of lines: 0 Number of boundaries: 112
Number of areas: 39 Number of islands: 19
GRASS GIS 7.3.svn > v.category demo op=report
Layer/table: 1/demo
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 38 1 75
area 0 0 0
face 0 0 0
kernel 0 0 0
all 38 1 75
Thanks, Dave
Layer/table: 1/demo
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 38 1 75
area 0 0 0
face 0 0 0
kernel 0 0 0
all 38 1 75
Thanks, Dave
grass-user mailing list
grass-user@.osgeo
d. vect has following option :
cat: Display category numbers of features
try to display the cat info for the polygones to check where the centroid is
missing.
have then a look at v.extract and extract only these polygones you need.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/areas-with-no-centroid-tp5297590p5297591.html
Hi Helmut,
    Thanks for the suggestion, but the area with no centroid doesn't have a cat. I think somehow I deleted the centroid instead of the area, and the cat went with it.
    It's not really causing any problems I'm aware of; it's just odd.
Thanks, Dave
Layer/table: 1/demo
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 38 1 75
area 0 0 0
face 0 0 0
kernel 0 0 0
all 38 1 75
Thanks, Dave
grass-user@.osgeo
missing.
HTH
best regards
Helmut
grass-user@lists.osgeo.org
have a cat.
that's exactly what I've meant.
then do v.extract cats="cats of the polygones with cat" to extract only
from the v.extract manual :
cats=range
Category values
Example: 1,3,7-9,13
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/areas-with-no-centroid-tp5297590p5297603.html
Thanks Helmut
v.extract demo cats=1-100 out=new
worked like a charm! Sorry I missed your point the first time.
Dave
have a cat.
cats=range
Category values
Example: 1,3,7-9,13
best regards
Helmut
