[GRASS-user] areas
hi, I was wondering if it is posible to measure areas and distances inside GRASS, and save the values in a table.
wich commands do I have to use?
thank you
Isabel
2008/4/11, Isabel Alfaro Cardozo <isabelalfaro@gmail.com>:
if you mean areas of polygons and length of linear feature you can use
v.to.db module. For distance measuring use d.measure or GUI tool.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
This depends whether you work in raster or vector, but in vector look at the following:
v.to.db
v.distance
For raster maps you should check out
r.distance
r.stats (possible with r.clump)
Moritz
thank you
Isabel
grass-user mailing list
grass-user@lists.osgeo.org
thank you
Isabel
2 more examples for categorised raster maps (in this case I have a
fragment of the GLC2000 land cover map):
r.report -nh glc2000_areas units=h
| Category Information | |
| #|description | hectares|
| 2|Tree Cover, broadleaved, deciduous, closed . . . . . . . . . . |
1300.00|
| 4|Tree Cover, needle-leaved, evergreen . . . . . . . . . . . . . |
46,000.00|
| 6|Tree Cover, mixed leaf type. . . . . . . . . . . . . . . . . . |
16,500.00|
|11|Shrub Cover, closed-open, evergreen. . . . . . . . . . . . . . |
85,900.00|
|12|Shrub Cover, closed-open, deciduous. . . . . . . . . . . . . . |
600.00|
|16|Cultivated and managed areas . . . . . . . . . . . . . . . . . |
16,100.00|
|TOTAL |166,400.00|
r.stats -an glc2000_areas
r.stats: 100%
2 13000000.000000
4 460000000.000000
6 165000000.000000
11 859000000.000000
12 6000000.000000
16 161000000.000000
Isabel:
Martin:
see also the m.distance script using Python/SWIG:
(non-interactive backend module; takes a series of coords)
  http://trac.osgeo.org/grass/browser/grass/trunk/swig/python/examples/
both d.measure (middle click) and m.distance will report area too.
see also d.where to get a list of coordinates to feed into a area
measurement tool or something like v.in.ascii or r.in.poly.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
