[GRASS-user] 'ARNing: Cannot open driver 'dbf"
I have installed GRASS 6.1 CVS and using the grass61.bat. However when
I run certain DB related command like g.copy, it also returns
“:No such driver available
'ARNing: Cannot open driver 'dbf”
do I need to do something in the GRASS settings?
Thanks
Raymond
Send instant messages to your online friends http://uk.messenger.yahoo.com
":No such driver available
try testing/connecting to a database driver with the db.connect module.
Hamish
thanks a lot, but the following driver error is still prompted as follows:
GRASS 6.1.cvs (spearfish60):~>v.db.connect -p map=roads driver=dbf
Vector map is connected by:
layer <1> table in database <home/xxx/spearfish60/PERMENANT/dbf/>
hoguh driver with key
GRASS 6.1.cvs (spearfish60):~>g.copy vect=roads,roads_local
COPY [roads@PERMANENT] to current mapset as [roads_local]
DBMI-DBF driver error:
Cannot open dbf database: roads
WARNING: Cannot open database ‘roads’
no database is open
WARNING: Cannot copy table
WARNING: Cannot copy roads@PERMANENT to current mapset as roads_local
Hamish
  Vector map <roads> is connected by:
  layer <1> table <roads> in database <home/xxx/spearfish60/PERMENANT/dbf/>
  hoguh driver <dbf> with key <cat>
  WARNING: Cannot open database 'roads'
  no database is open
Does the database exist on the disk?
g.gisenv
cd $MAPSET
ls dbf/
Hamish
hi,
actually, it is sample from spearfish60.
when I type
GRASS 6.1.cvs(spearfish60):~>g.gisenv
it display:
GISDBASE=/home/xxx
LOCATION_NAME=spearfish60
MAPSET=user1
MONITOR=x1
GRASS_GUI=tcltk
GRASS 6.1.cvs(spearfish60):~>cd$MAPSET
it change back to current directory.
do I need to set something before running the command?
Thank a lot.
Raymond
Vector map
  when I type
  it display:
  GISDBASE=/home/xxx
  MAPSET=user1
  MONITOR=x1
  GRASS_GUI=tcltk
$MAPSET is empty, so "cd$MAPSET" is the same as "cd"
(shell variables vs. GRASS variables)
try:
eval `g.gisenv`
cd "$GISDBASE/$LOCATION_NAME/$MAPSET"
ls dbf/
Hamish
hi,
I tried
GRASS 6.1.cvw(spearfish60):~ > eval ‘g.gisenv’
GISDBASE=/home/f1fuser
MAPSET=user1
MONITOR=x1
GRASS_GUI=tcltk
GRASS 6.1.cvs (spearfish60):~>cd “$GISDBASE/$LOCATION_NAME/$MAPSET”
GRASS 6.1.cvs (spearfish60):// >ls dbf/
nothing appears even the prompt “GRASS 6.1.cvs (spearfish60):// >” untill I click “Ctrl C”.
Anything wrong?
Thanks in advance.
Raymond
when I type
it display:
GISDBASE=/home/xxx
MAPSET=user1
MONITOR=x1
GRASS_GUI=tcltk
$MAPSET is empty, so “cd$MAPSET” is the same as “cd”
try:
eval g.gisenv
ls dbf/
Hamish
Raymond Fu wrote:
I tried
  GRASS 6.1.cvw(spearfish60):~ > eval 'g.gisenv'
that's
  eval `g.gisenv`
using back-quotes (`) (for me that's on the same key as the ~)
echo $MAPSET
Hamish
hi,
The result is as follows:
GRASS 6.1.cvs(spearfish60):~>eval g.gisenv
GRASS 6.1.cvs(spearfish60):~>echo $MAPSET
user1
GRASS 6.1.cvs(spearfish60):~>cd “$GISBASE/$LOCATION_NAME/$MAPSET”
GRASS 6.1.cvs(spearfish60):~/spearfish60/user1> ls dbf
ls: cannot access dbf: No such file or directory.
I guess the reason is because the road is orginally in PERMENANT Mapset. What I am trying to do to copy the road from PERMENANT to user1 Mapset using g.copy command.
do you have any idea?
Thanks a lot,
Raymond
Hamish <hamish_nospam@yahoo.com> wrote:
Raymond Fu wrote:
I tried
that’s
eval g.gisenv
using back-quotes (`) (for me that’s on the same key as the ~)
echo $MAPSET
Hamish
Raymond Fu wrote:
I tried
that’s
eval g.gisenv
echo $MAPSET
Hamish
  GRASS 6.1.cvs(spearfish60):~>eval `g.gisenv`
  user1
  GRASS 6.1.cvs(spearfish60):~>cd "$GISBASE/$LOCATION_NAME/$MAPSET"
sorry,
eval `g.gisenv`
cd "$GISBASE/$LOCATION_NAME/PERMANENT"
ls dbf/
I am interested to know if the DBF file works.
d.rast roads
d.what.vect
Hamish
hi,
Today I try again.
GRASS 6.1.cvs(spearfish60):~> eval g.gisenv
GRASS 6.1.cvs(spearfish60):~> echo $MAPSET
user1
bash: cd: /usr/local/grass6.1.cvs/spearfish60/user1: No such file or directory.
I try to exame the location from window explorer, and I can found the road.dbf in c:\cwgin\home\xxx\spearfish60\PERMANENT\dbf\
Both command d.rast roads, d.what.vect works fine. The road can be displayed and I can use mouse to read the features attributes from a prompt window.
Thanks.
Raymond
user1
sorry,
eval g.gisenv
cd “$GISBASE/$LOCATION_NAME/PERMANENT”
ls dbf/
d.rast roads
d.what.vect
Hamish
  prompt window.
if d.what.vect can read the DBF file ok, but g.copy can't, I'm not sure
why. Does your user name (\home\xxx ?) have a space or non
alpha-numberic character in it?
Can anyone else copy vector maps in windows?
Hamish
Hamish wrote on 12/07/2006 07:05 AM:
  prompt window.
Hamish,
in manage/lib/do_copy.c, 'mkdir' is used which IMHO needs a special
treatment
on Windows. See for example lib/gis/mapset_msc.c
hi,
Sorry, I work in a user level, and know not much about C. Can you suggest me what the “special treatment” and how to make the “special treatment” by command line or other ways so that the g.copy can be run without error?
Thanks in advance.
Raymond
prompt window.
if d.what.vect can read the DBF file ok, but g.copy can’t, I’m not sure
Hamish,
in manage/lib/do_copy.c, ‘mkdir’ is used which IMHO needs a special
treatment
suggest me what the "special treatment" and how to make the
"special treatment" by command line or other ways so that the g.copy
(it's probably a bug in the code, you'll have to wait for a new version?)
they quick & very dirty way to copy a vector map is to go into
$MAPSET/vector/ and just copy the folder with the vector to something
named something else, then do the same with $MAPSET/dbf/$MAPNAME.dbf
using the same name, and finally update the $MAPSET/vector/$MAPNAME/dbln
file in a text editor.
Hamish
  prompt window.
If it is still useful, I successfully copied and displayed a couple of vectors (with DBF table) using cygwin/grass6.1.cvs
Luigi
Thanks. But my problem is that “copy” is an example of errors encountered. It ocurrs for many operations in GRASS such as query, import.
Here is another example.
GRASS 6.1.cvs (spearfish60):~>v.db.connect -p map-roads driver=dbf
layer <1> table in database </home/xxx/spearfish60/PERMANENT/dbf/> through driver with key
GRASS 6.1.cvs (spearfish60):~> echo “select * from roads”|db.select
cannot open dbf database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
I am using GRASS version 6.1.CVS(grass-cvs) from http://geni.ath.cx/grass.html
any idea?
Thanks in advance.
Raymond
(it’s probably a bug in the code, you’ll have to wait for a new version?)
Hamish
Raymond Fu wrote:
  any idea?
does the cygwin version work if you are using the "native" MSys version?
or vice versa?
In the past Glynn asked if anyone would make a 6.2.0 version for Cygwin?
(now 6.2.1rc1) Non-native, but much more stable vs 6.2.0+Msys as Msys
stuff is still in active development in the 6.3 line.
Hamish
hi
does the cygwin version work if you are using the “native” MSys version?
or vice versa?
I am using XP Window. Would you please tell me more information about that version? Where can I get the version? How to install the version?
Raymond
Raymond Fu wrote:
any idea?
or vice versa?
Hamish
> version? or vice versa?
the version?
Are you using the 6.1.cvs (April 17, 2006) Cygwin version or the 6.3.cvs
(Sept 17, 2006) MSys version?
both from http://geni.ath.cx/grass.html
Hamish
