Hamish
1
espiritoCZ wrote:
> The file structure is very simple:
> X [tab] Y [tab] Z
> (e.g.:
> 23.3375 45.8959 -2.345
Markus:
I have tried the line you have indicated and stored it as
file points.csv. Then imported with:
v.in.ascii -z in=points.csv out=points3d x=1 y=2 z=3 fs=tab
also r.in.xyz could help if it is millions of points or
pre-gridded.
Hamish
Ok, thanks to both,
I was quite sure that it would be a piece a cake for you
All the best!
Milan
(not tried yet, but i believe i will manage now)
Hamish wrote:
> X [tab] Y [tab] Z
> (e.g.:
Markus:
pre-gridded.
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/ascii-dem-opening--tp2664060p2668981.html
