[GRASS-user] ascii to dem
I have imported into GRASS an ascii file (bathymetry) like this:
r.in.ascii in=/home/toni/tmp/38n34n9w2w/baty2.xyz out=bati
north: 38
south: 34
east: -2
west: -9
rows: 241
cols: 421
-9 38 -137
-8.98333 38 -127
-8.96667 38 -119
-8.95 38 -112
-8.93333 38 -101
-8.91667 38 -81
-8.9 38 -63
-8.88333 38 -45
-8.86667 38 1
-8.85 38 8
How do I transform it into a 'typical' dem map. It's to say a continous-aspect dem map not a dotted-aspect one?
TIA
Antonio
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 14/03/07 10:47, antonio rodriguez wrote:
north: 38
south: 34
east: -2
west: -9
rows: 241
cols: 421
-9 38 -137
-8.98333 38 -127
-8.96667 38 -119
-8.95 38 -112
-8.93333 38 -101
-8.91667 38 -81
-8.9 38 -63
-8.88333 38 -45
-8.86667 38 1
-8.85 38 8
r.to.vect & v.surf.*
or
v.in.ascii & v.surf.*
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFF+AN/MiPFf/8qzFYRApPMAKCV8FC2A1KTp1cRt/mNen7UHW1xzwCcCYzW
r6KN5nM3nF3lvRi9NTikapo=
=v0fk
-----END PGP SIGNATURE-----
north: 38
south: 34
east: -2
west: -9
rows: 241
cols: 421
-9 38 -137
-8.98333 38 -127
-8.96667 38 -119
-8.95 38 -112
-8.93333 38 -101
-8.91667 38 -81
-8.9 38 -63
-8.88333 38 -45
-8.86667 38 1
-8.85 38 8
That looks like x,y,z data, not a 2D ASCII array. r.in.ascii wants a 2D
array of z values, x,y are calculated from header. (see the example in
the help page)
Use r.in.xyz to import your data after crafting g.region settings by hand.
Hamish
north: 38
south: 34
east: -2
west: -9
rows: 241
cols: 421
-9 38 -137
-8.98333 38 -127
-8.96667 38 -119
-8.95 38 -112
-8.93333 38 -101
-8.91667 38 -81
-8.9 38 -63
-8.88333 38 -45
-8.86667 38 1
-8.85 38 8
the help page)
Hi Hamish,
I understand the issue of using r.in.xyz but I'm having problems with the import:
r.in.xyz z=3 fs='space' input=baty2.xyz out=baty
Scanning data ...
ERROR:Not enough data columns. Incorrect delimiter or column number? Found
      the following character(s) in row 1:
      [north: 38]
If I erase the header of baty2.xyz (the first six lines above):
Scanning data ...
      [-9 38 -137]
Don't know what I'm doing wrong since the 1st column holds the x's (longitude) values, the 2nd column, lat values, and 3rd column the z values (elevation +/-) The column delimiter is 'space'
Antonio
Hamish
>> north: 38
>> south: 34
>> east: -2
>> west: -9
>> rows: 241
>> cols: 421
>> -9 38 -137
>> -8.98333 38 -127
>> -8.96667 38 -119
>> -8.95 38 -112
>> -8.93333 38 -101
>> -8.91667 38 -81
>> -8.9 38 -63
>> -8.88333 38 -45
>> -8.86667 38 1
>> -8.85 38 8
> 2D array of z values, x,y are calculated from header. (see the
> example in the help page)
> hand.
Hi Hamish,
the import:
Scanning data ...
Found
      [north: 38]
Correct. You could also have commented them out with the hash (#) char:
# north:
# south:
Scanning data ...
Found
      [-9 38 -137]
try fs=tab, or fs=space without the 'quotes' (if done from the GUI
window, from the command line 'quotes' shouldn't matter).
AndI think it is hoping for just one space,
this might help:
cat bathy2.xyz | awk '{print $1 $2 $3}' > bathy3.txt
Hamish
Scanning data ...
Found
      [-9 38 -137]
this might help:
Hamish
Thanks Hamish, it helps a lot. What a powerful tool is awk (if one knows how to use it :-[ )
The raster data is imported fine, but when trying to convert it to a vector file:
r.to.vect in=bati3 out=bati3
Extracting lines ...
update_list: crowded cell 8H (1,2)
ERROR:Raster map is not thinned properly.
      Please run r.thin.
I do that, but:
r.thin in=bati3 out=bati3_thin
File bati3 -- 241 rows X 421 columns
Bounding box: l = 2, r = 422, t = 2, b = 242
Pass number 1
Deleted 1320 pixels
Pass number 2
Deleted 1312 pixels
Pass number 3
Deleted 1304 pixels
Pass number 4
Deleted 1296 pixels
At the end of the process almost all the data were erased. What is r.thin finding so wrong in my data that it deletes almost everything?
Antonio
vector file:
      Please run r.thin.
I do that, but:
Pass number 1
Deleted 1320 pixels
Pass number 2
Deleted 1312 pixels
Pass number 3
Deleted 1304 pixels
Pass number 4
Deleted 1296 pixels
r.thin is appropriate if your raster data consists of lines, e.g. a
scanned contour map. It thins the lines so that they are only one cell
wide.
If you are trying to convert filled areas to vector areas, don't use
r.thin. You also need to pass feature=area to r.to.vect.
