[GRASS-user] Assign attributes of start and enpoints to, connecting lines
On 12/12/10 4:00 AM, grass-user-request@lists.osgeo.org wrote:
Message: 4 Date: Sat, 11 Dec 2010 17:09:06 +0200 From: Micha Silver <micha@arava.co.il> Subject: Re: [GRASS-user] Assign attributes of start and enpoints to connecting lines To: Hanlie Pretorius <hanlie.pretorius@gmail.com> Cc: grass-user@lists.osgeo.org Message-ID: <4D039412.3080707@arava.co.il> Content-Type: text/plain; charset=UTF-8; format=flowed On 12/10/2010 08:19 AM, Hanlie Pretorius wrote:
> Hi Micha,
> Thanks for the reply.
> I tried your method using the GUI, and it seems one cannot have a
> from_type of 'line', only of 'point' or 'centroid'.
Yes, you're right. Sorry for misleading you. The 'from' map can be only
points, so this won't help to get the node labels into the rivers table.
Convert the start and end nodes to points using v.to.points, and then use v.distance?
Richard
