[GRASS-user] Assign attributes of start and enpoints to connecting lines
Hi Richard,
Your suggestion worked in principle, but the whole operation needs
more work. I ended up with the same node names in the start and end
node columns, so I think a script is needed to identify the start and
end nodes based on the direction of the flow of the river. An
elevation column in the points layer could provide this information.
Regards
Hanlie
Date: Sun, 12 Dec 2010 07:33:41 +1100
Subject: Re: [GRASS-user] Assign attributes of start and enpoints to,
  connecting lines
To: grass-user@lists.osgeo.org
Message-ID: <4D03E025.7040203@ozemail.com.au>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Convert the start and end nodes to points using v.to.points, and then
use v.distance?
Richard
