Hi Some time ago I imported some Aster Gdem into grass, now I’m trying to do the same with the new version, but is full of artifacts. Could someone would be so kind to remember me the process to remove artifacts once laded in Grass.
Thanks in Advance.
Javier García Prieto
On Mon, Feb 4, 2013 at 12:06 AM, javier Garcia Prieto
<fjgarciaprieto@hotmail.com> wrote:
Hi Some time ago I imported some Aster Gdem into grass, now I'm trying to do
Grass.
Did you import the same tile and it looks different? Could be simply
be a color table issue? (you may check the histogram after having set
the computational region properly).
