On Wed, 2008-09-24 at 14:41 +0200, Markus Metz wrote:
Nikos Alexandris wrote:
>> r.info composite_b123 -tr
> min=0
> max=32767
> datatype=CELL
> [Raster MASK present]
> 1st attempt to export:
> > r.out.gdal in=composite_b123
> out=/home/nik/grassdb/peloponnese/data/exports/composite_b123.tif
> Exporting to GDAL data type: UInt16
> Segmentation fault
> 2nd attempt to export without any change:
> Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
> 100%
> WARNING: Input raster map constains cells with NULL-value (no-data). The
> value -32768 was used to represent no-data values in the input
> map.You can specify nodata value by nodata parameter.
> r.out.gdal complete.
Apart from the segmentation fault answered by Glynn, I see more problems
here.
The nodata value of -32,768 is not valid, effectively discarding nodata
information, because the range of UInt16 is 0 to 65,535 and -32,768 is
out of range, i.e. there are no cells with -32,768 in the output
GeoTIFF. The range of composite_b123 is 0 to 32,767, therefore a
reasonable nodata value would be anything between 32,768 and 65,535. You
can try to use r.out.gdal with the options e.g. type=UInt16 nodata=32768
or type=Int16 nodata=-32768. Generally it seems to be a good idea to
specify the options type and nodata (if needed) for r.out.gdal
The next problem I suspect is the export of a raster probably generated
with r.composite (as the name suggests). This will only be displayed
with the same colours as in GRASS if the colortable provided with the
GeoTIFF metadata is properly interpreted. As I have shown previously [1]
this is not always the case, especially for UInt16, even GRASS struggles
with the re-import of UInt16 type GeoTIFFs [2]. A safer alternative
would be to put the three rasters used for r.composite in a group and
export the group with type=Byte if possible. The resulting GeoTIFF
should be a RGB image that can be displayed with any image viewer, an
easy way to check that the three bands are assigned red, green, and blue
as intended, otherwise swap the order in the ref file.
I hope that helps
[1] http://trac.osgeo.org/grass/ticket/73#comment:13
[2] http://trac.osgeo.org/grass/ticket/73#comment:15
Markus,
your attention to details is very much appreciated.
The above reported range is from a composite image created r.composite.
But it was just a test to see whether it works or not. I can't export
any viewable composite (at least for OpenEV with which I work) if max
value exceeds 255. It works if you use levels=x (where x something which
will give a max < 256 --- in my case it was levels=6).
Anyhow, exporting the group of 3 bands with r.out.tiff or r.out.gdal
works but there is something important: I don't like the white
background. I would like to have a black backgroud surrounding my map. I
could not get that really. I think I managed to see that only when I
reduced levels with r.composite. Don't remember right now but I think
rescaling initial bands with range from 0 up to 8000 in to 0 to 255 and
export the group did not work either.
If I am not wrong this has to do with transparency. I was trying all
possible export methods (r.out.gdal, r.out.tiff, r.out.png) but I didn't
nail a good method.
Thank you,
Nikos
