On 4/09/12 10:58 PM, grass-user-request@lists.osgeo.org wrote:
Message: 2
Date: Mon, 03 Sep 2012 16:10:58 -0700
To:grass-user@lists.osgeo.org
Subject: [GRASS-user] Attribute table disappears
Message-ID:<50453902.2000501@quercus.org>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedI had a simple attribute table working using the sqlite driver, and had
successfully digitized a dozen or so areas in a couple of sessions. Now
the table has disappeared according to various tools. I have only one
layer in my map area. when I try to add a table so I can rebuild my
data, addtable complains that there is already a link to a table from
layer 1, so I cannot start over. Any suggestions for how to proceed
(and how to avoid this in the future) would be appreciated.
Version is 6.4.2 under fedora 16 64-bit.tia
David -
The table might be gone, but Grass-GIS still thinks it exists - you have to delete the connection to the table:
v.db.connect -d <map> <table_name>
Then you'd recreate a table with v.db.addtable
Richard
