There are two little issues that recently popped up in GRASS 7
- I performed a pairwise network analysis with v.net.allpairs.
The attribute table to the output map “map” that is produced is called “map_1” (note: _1 !!). Thus when I then try to export the attribute table to a csv using v.out.ogr I get following warning (which is of course net a problem):
db.out.ogr input=map_1 dsn=path/to/csv/file.csv format=CSV
WARNING: Vector map <map_1> not found -->right, because there is no map_1, the map is called “map”
Is that an intended behaviour that the corresponding attribute table for v.net.allpairs gets a ending of “_1”?
- It seems that the option for the output in db.out.ogr is maybe set wrong (http://svn.osgeo.org/grass/grass/trunk/scripts/db.out.ogr/). Is it really necessary that the outputfile already exists because the GUI asks to select a file rather than allow specifying the path to the file? I want to create a new csv with that module, so maybe the following needs to be changed from “old” to “new”:
#%option G_OPT_F_INPUT
#% key: dsn
#% gisprompt: old,bin,file
#% description: Table file to be exported or DB connection string
#% required : yes
#%end
best regards,
Johannes
On Wed, Apr 24, 2013 at 3:01 PM, Johannes Radinger
<johannesradinger@gmail.com> wrote:
1) I performed a pairwise network analysis with v.net.allpairs.
The attribute table to the output map "map" that is produced is called
"map_1" (note: _1 !!).
This is because if a table with node attributes exists in the input
vector, this table is also copied to the output vector and should have
the name map_2.
problem):
the map is called "map"
v.net.allpairs gets a ending of "_1"?
2) It seems that the option for the output in db.out.ogr is maybe set wrong
"old" to "new":
#% key: dsn
#% required : yes
#%end
or simpler
#%option G_OPT_F_OUTPUT
#% key: dsn
#%end
Fixed in r55983.
Markus M
@Markus M: Thank you for the fix.
However, somehow I am not able to export the attribute table that is created by v.net.allpairs.
There is nothing special with the v.net.allpairs operation, just 13 points along the network. The result
looks okay and the attribute table is as it should be. When I try db.out.ogr nothing is produced (db.out.ogr
works with other tables):
db.out.ogr input=map_1 dsn=/home/radinger/Analysis/test format=CSV
I get the warning above that the vector map <map_1> can not be found and there is no output created at
all. Can anyone reproduce that problem with a net.allpairs-attribute table?
/Johannes
On Wed, Apr 24, 2013 at 7:30 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
the name map_2.
problem):
“old” to “new”:
#% key: dsn
#% required : yes
#%end
or simpler
#% key: dsn
#%end
Fixed in r55983.
Markus M
On Thu, Apr 25, 2013 at 10:33 AM, Johannes Radinger
by v.net.allpairs.
Yes, fixed in r55991. The db.out.ogr module was asking for an input
table and then used that name as vector name, that does not work.
Markus M
/Johannes
> Hi,
the name map_2.
> problem):
> map_1,
> wrong
> really
> select
> create a
> from
> "old" to "new":
> #% key: dsn
> #% required : yes
> #%end
or simpler
#% key: dsn
#%end
Fixed in r55983.
Markus M
Hi Markus,
that is working now for me fine!! Thank you.
Just out of curiousity:
Could there be the case that there is a table that is not (anymore, yet) connected to a vector? In such
a case it is not possible to export the table as the input is defined by a vector map and the layer number?!
/Johannes
On Thu, Apr 25, 2013 at 11:17 AM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
by v.net.allpairs.
Markus M
/Johannes
the name map_2.
problem):
map_1,
wrong
really
select
create a
from
“old” to “new”:
#% key: dsn
#% required : yes
#%end
or simpler
#% key: dsn
#%end
Fixed in r55983.
Markus M
On Thu, Apr 25, 2013 at 11:52 AM, Johannes Radinger
Hi Markus,
db.out.ogr uses internally v.out.ogr which is a bit against the logic
of db.* modules which should work with tables, not vectors.
You can still export any table with either db.select dumping to a text
file or with db.copy, adjusting from_database, from_driver,
from_table, to_database, to_driver, to_table.
Markus M
/Johannes
> Hi,
> created
> by v.net.allpairs.
> points
> db.out.ogr
> table?
Markus M
> /Johannes
>> > Hi,
>> > called
>> the name map_2.
>> > a
>> > problem):
>> > map_1,
>> > for
>> > wrong
>> > really
>> > select
>> > create a
>> > from
>> > "old" to "new":
>> > #% key: dsn
>> > #% required : yes
>> > #%end
>> or simpler
>> #% key: dsn
>> #%end
>> Fixed in r55983.
>> Markus M
On Thu, Apr 25, 2013 at 12:18 PM, Markus Metz
Note: db.out.ogr was born as "quick fix" shell script in GRASS 6.
Given the new possibilities of Python programming in GRASS 7, both
scripts db.out.ogr and db.in.ogr should be rewritten to avoid that the
v.*.ogr modules are called any longer.
markusN
