[GRASS-user] AutoCAD import [was ]2nd edition book?
On 11/18/06, infotechsys@pivot.net <infotechsys@pivot.net> wrote:
<snip>
GRASS read Autocad files?
You can save drawing in dxf format from AutoCAD, and then v.in.dxf in
GRASS will do the work.
H.S.Rai
H.S.Rai wrote:
<snip>
or import DWG format with v.in.dwg if you are willing to abide by
OpenDWG's terms and compile it yourself.
Hamish
Hi Rai,
  1. Do we have to re-compile for
    v.in.dxf to work in GRASS ?.
    I have earlier used it this way. Pl clarify.
Ravin Kumar
Sponsored Link
Mortgage rates near 39yr lows. $310,000 Mortgage for $999/mo - Calculate new house payment
I used it with GRASS 6.2.0RC3 compiled myself with default options.
So, in my opinon, GRASS 6.2.0 should have it in its compiled version.
You should have one stable version and other CVS on your system. That
way you have both world in your hand :wink:
H.S.Rai
Pl check it. I am not sure that the CVS has
v.in.dxf working in GRASS 6.2 CSV.
Ravi Kumar
Sponsored Link
Mortgage rates as low as 4.625% - $150,000 loan for $579 a month. Intro-*Terms
I compiled CVS, but could not run gis.m. However from command prompt,
I found v.in.dxf is not there.
But, it is there in GRASS6.2.0RC3
H.S.Rai
v.in.dxf is indeed a standard module in GRASS 6.2.0, it should be there.
v.in.dwg is not, due to OpenDWG license restrictions. You will need to
get the OpenDWG library and compile the module yourself if you want that.
I suspect that Hardeep's installation is broken -- IIRC the ps.map
module was missing as well? Try rebuilding GRASS and look at the error
list at the end.
Hamish
Yes, It is there in 6.2.0, I compiled it also, and with default
options, and found it to be there.
H.S.Rai
that.
You could also try OrbisCAD http://orbiscad.sf.net which does import DWG
files and can output Shapefiles as well to be used in GRASS.
It is based on the jdwg library (not very clear to me its licensing btw)
Best regards,
Stefano
Stefano Costa
http://www.iosa.it Open Archaeology
http://list.iosa.it International Mailing List
Jabber: steko@jabber.linux.it
I am able to compile CSV, v.in.dxf is there in GRASS6.3.cvs
H.S.Rai
