Dear Jean,
If I understand you correctly what you are looking for is to make a swath profile along curved geomorphic features e.g botton valleys. I think that if you want to this in grass gis, it would be enough to create a mask using the the polygon you show in your picture and then extract that area using r.mapcalc. You also can use the geomorphons approach, described by Vaclav, but you have to be careful with the parameters, since they will yield different results depending on your parameters.I would rather use gemorphons instead of r.param.scale, since it is scale independent. If you want something more specific I suggest you to take a look at this paper it might give some ideas about the topic.
http://www.earth-surf-dynam.net/2/97/2014/esurf-2-97-2014.pdf
Best regards..
Rengifo Ortega
Message: 4
Date: Thu, 12 Nov 2015 11:09:48 +0100
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] Automatic extraction of valley features
Message-ID: <ea169b38242db4eab8424817c2c2149a@enoreth.net>
Content-Type: text/plain; charset=US-ASCII; format=flowedHi,
I would like to know how to extract a valley feature from a DEM as a
polygon : the wanted result isn't equal to a watershed or a sub-basin,
it is the cumulated shape of the two slopes and the bottom where the
stream is located.As I do not master the geomorphological vocabulary, here is a image
showing the desired outcome :
https://drive.google.com/open?id=0B1sJg8zddqSPUk9BcTdncVRNNHcI'm using GRASS7, I've tried r.watershed and several r.stream.* modules
but my lack of knowledge in this domain is blocking. The elevation data
used is the EU-DEM.Regards,
Jean-Roc------------------------------
Message: 5
Date: Thu, 12 Nov 2015 07:41:47 -0500
To: Jean-Roc Morreale <jr.morreale@enoreth.net>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Automatic extraction of valley features
Message-ID:
<CABo5uVs7Qrs5F+mRX_baN29+XUTFMuOxixAXFscBG7n8hAYvRA@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"Hi,
On Thu, Nov 12, 2015 at 5:09 AM, Jean-Roc Morreale <jr.morreale@enoreth.net>
wrote:> I would like to know how to extract a valley feature from a DEM as a
> polygonThe classic way would be to use r.param.scale with method=feature, but I
would recommend using r.geomorphon by Stepinski and Jasiewicz (2011, 2013).Both modules will give you a raster map. You can use r.to.vect to get
vector polygons. To get just the valley use either raster algebra
(r.mapcalc) on the raster map or v.extract on the vector map.Note that r.geomorphon module is in GRASS Addons repository, so use e.g.,
g.extension r.geomorphon to get it.Vaclav
https://grass.osgeo.org/grass70/manuals/r.param.scale.html
https://grass.osgeo.org/grass70/manuals/addons/r.geomorphon.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151112/cf81f265/attachment-0001.html>------------------------------
Message: 6
Date: Thu, 12 Nov 2015 12:59:47 +0000
From: "Blumentrath, Stefan" <Stefan.Blumentrath@nina.no>
To: Vaclav Petras <wenzeslaus@gmail.com>, Jean-Roc Morreale
Message-ID: <a483ccb78ff7490284f5dba6982ce0eb@NINSRV23.nina.no>
Something to have in mind is that your definition of a valley will be heavily scale dependent, e.g. what depth and width (and possibly even length) do you consider as a valley. As a consequence, also results from r.param.scale and r.geomorphon are likewise scale dependent (where scale is - amongst others - accounted for in neighborhood parameter).
Another option to identify valleys is the Topographic Position Index (TPI), which is defined as the altitude of a pixel in relation to the average altitude of the pixels in the neighborhood. In GRASS terms:
r.neighbors input=dem output=dem_avg_11 size=11
r.mapcalc expression=”TPI_11=dem-dem_avg_11”Negative TPI values indicate valleys. However, a drawback of TPI is that it may also give negative values at the foot of a slope, and that the signal will “fork” in wide U-valleys…
In order to address scale effects, you can use a multiscale approach with increasing neighborhoods for all the above methods…
StefanFrom: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Vaclav Petras
Sent: 12. november 2015 13:42
Subject: Re: [GRASS-user] Automatic extraction of valley featuresHi,
On Thu, Nov 12, 2015 at 5:09 AM, Jean-Roc Morreale <jr.morreale@enoreth.net<mailto:jr.morreale@enoreth.net>> wrote:
I would like to know how to extract a valley feature from a DEM as a polygonThe classic way would be to use r.param.scale with method=feature, but I would recommend using r.geomorphon by Stepinski and Jasiewicz (2011, 2013).
Both modules will give you a raster map. You can use r.to.vect to get vector polygons. To get just the valley use either raster algebra (r.mapcalc) on the raster map or v.extract on the vector map.
Note that r.geomorphon module is in GRASS Addons repository, so use e.g., g.extension r.geomorphon to get it.Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151112/40ca7004/attachment.html>------------------------------
Subject: Digest Footer
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user------------------------------
End of grass-user Digest, Vol 115, Issue 13
Rengifo Yahoo <rengifoo@yahoo.de>
