Hi to all,
I'm trying to use GRASS 6.4 (installed on UBUNTU) to realize a system to automate the orthorectification process.
I have a group of little images (chip of 256x256 pixel) that I want to use to orthorectify an image.
Can grass use the little chip to create the RPC polynomial without any external action? I try i.points.auto, but I must set the GCP manually...
Thank you
View this message in context: http://n2.nabble.com/Automatic-Orthorectification-tp2531561p2531561.html
the GCPs are located in each image at known locations, you can create
necessary files in a batch script:
- you have to create the group for each image (i.group)
- you have to set the target and ref files for the group (i.target)
- you have to create the POINTS file - manually
try to rectify one image by hand and then see grassdata/LOCATION/MAPSET/group/GROUP/*
however, if the position of GCPs is unknown to you, I'm affraid, you
have to do it by hand
jachym
On Wed, Mar 25, 2009 at 03:04:43AM -0700, Petrone Orlando Mauro wrote:
Hi to all,
Thank you
Sent from the Grass - Users mailing list archive at Nabble.com._______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299 ED8A C8AB 74B8 08D4 E08F
On Thu, Mar 26, 2009 at 7:57 AM, Jachym Cepicky
Maybe you can hack i.points.auto to
http://grass.osgeo.org/wiki/Image_processing#Geocoding
"seed" it with a priori knowledge or you start with very rough resolution
and then increase it in a cycle to get more precise chips. This would
require source code modification of course to take out the interactive
part (which is obsolete for GRASS 7 anyway and needs to be rewritten).
I have this little chip (256x256px) that are taken from an orthorectified image, so I have all the coordinate for all them. I want to use this little image to orthorectify a new image. What are the right step for this?
Mauro
Mauro
View this message in context: http://n2.nabble.com/Automatic-Orthorectification-tp2531561p2537928.html
Mauro
write a script, which would assing source and target coordinates
automatically (creating the POINTS file) and call i.group, i.target &&
i.rectify at the end
jachym
Jachym Cepicky
