[GRASS-user] automating map production in Grass
All grass commands can be run either from the gui or command line. The gui just creates the command and executes it. So you can create a shell script with a text editor that has all your commands, and does the usual things that shell scripts can do and run it from the window that appears when you launch grass.
Jerry
---- Original message ----
Date: Wed, 20 Feb 2008 18:08:00 -0500
From: "Alysson Whitlam" <alysson.whitlam@gmail.com>
Subject: [GRASS-user] automating map production in Grass
To: grass-user@lists.osgeo.org
  I am just beginning to work with Grass, although I
  am fairly experienced with ArcGIS, including
  scripting for map production and geoprocessing
  (Python and VBA). Basically, I am looking to
  automate map production in Grass, using a script
  (Python or Perl preferably?). (I have to output
  several hundred maps, based on sections of a polygon
  layer). Since I am just beginning to use Grass, I am
  wondering if anyone could please give me an idea if
  this type of task can be accomplished in Grass.
  Thanks very much,
  Alysson
________________
grass-user mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
